Question about Nikon Coolpix S9100 12.1mp Digital Camera red 26249
Google search camera says out of memory when memory chip does not have many pictures on it. When you change SD card the camera will not let you take pictures as it says out of memory
    New Friend:
I'm trying to text a picture on my Galaxy III smart phone and I'm getting this error message: Server Response Erron. How can a fix this error??
Posted on Jun 10, 2014
  • David Lisboa
    David Lisboa Jun 18, 2014
    davidlisboa@sbcglobal.net
SOURCE:
SOURCE: Lexar 1GB SD Card cannot be read.
I had the same problem. i dont know if this will work for yours, but what i did was when i had the card in the slot i pushed in it as far as i could with my finger nail and then it clicked right in.
Posted on Oct 14, 2008
chrlygrn
  • 149 Answers
SOURCE: How do I transfer pictures onto the memory card?
You should be able to transfer the pictures if it has built in memory. then transfer it to memory card the same way you'd take them off
Posted on Jan 08, 2009
  • 4 Answers
SOURCE: sd memory card cannot be used
This happenes when you remove the card while read/write process is still going on. Try some professional service who will retive the data for you from the mem card. Hope this helps.
Posted on Jan 19, 2009
  • 181 Answers
SOURCE: Problem in reading memory cards of NIKON D80
Some notebooks cannot read SD capacities of 4GB and above. The workaround is to use an external SD card reader.
NOTE: Please rate our help to keep this free service online
Posted on Jan 08, 2010
lock123
  • 6831 Answers
SOURCE: Camera won't accept an SD Memory Card anymore
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
How can i delete the pictures from the camera memory. something seems to be preventing me from doing so.
hi Moshe.
you have not said what model of camera.
but try this.
Copy any desired files from your camera's SD card to your computer. Ensure that the SD card is installed in the camera, then press the rear Menu button to wake thecamera. Press the rear Menu button repeatedly until "DELETE FILES" appears, press the top Shutter button to select.
How to Delete Files from microSD Cards - GoPro
https://gopro.com/.../How-to-Delete-Files-from-microSD-Cards-with-HERO3-HERO4
or go to this link and read up some more.
How to delete pictures from the camera memory Google Search
Dec 02, 2017 | Cameras
My phone show memory full,but i hae nothing on my SD card how do i move information from my phone memory to my SD card.
I had a similar issue. You need to go to the settings menu and check to see if your phone is recognized the chip. If no, power off your phone, take out the chip and reinstall it. If your phone is reading your chip, there are many apps you cc an download in google play. If your chip is not recognized, check it in a another phone.
Jan 28, 2015 | Huawei Ascend II battery 2200 mAh, Black
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
    Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
    Jan 04, 2010 | Kodak Easyshare C190 12MP Digital Camera...
    Chip says full after few pics
    The chip may not be inserted correctly. You can tell by seeing or not seeing SD symbol in the view screen. Try removing the SD card. Go through the memory and see if the pictures were saved to the camera or to the card. If the pictures were saved to the camera, turn off the camera and re-insert the card. See if the cards responds by showing more pictures available for taking and move the pictures to the card. If the pictures were saved to the card, then the card may need to replaced.
    Dec 31, 2008 | HP Photosmart R717 Digital Camera
    Retrieving pictures from SD card
    You may take a look at this SD card photo recovery guide which helped me get back deleted photos after reformat the SD card
    recover photos after reformat SD card
    good luck!
    Dec 03, 2008 | Kodak EasyShare C613 Digital Camera
    Unprotect memory card
    To set the memory card in unprotected mode, you have to do the following.
    On the side of the SD chip, there is a little switch. Shift the switch away from "lock", then insert the card back into the camera.
    This unprotects the card. You should now be able to take pictures and videos.
    If this does not solve the problem, then it is very likely that the SD card is faulty. I would recommend using Panasonic, Lexar or Sandisk memory cards.
    ~Lexar SD card
    ~1 Panasonic SD card
    ~2 Panasonic SD card
    ~Sandisk SD card
    Jul 13, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
    Polaroid Memory Chip problem
    Hey ashley131,
    One thing that might be happening is your SD card is set to the locked position on the side of your card. If this is not the case you could try opening the card by going to My Computer and right clicking on the memory card icon, then left click on open, and if it opens copy all the files shown and paste them into a folder of your choice, and then try opening the files using windows picture manager. If this doesn't work there are memory card recovery programs you should be able to use to recover your images just do an internet search for memory card recovery software. Once you have saved your images to your computer I would format your memory card in your camera, and the card should be able to be used again. I hope this helps!
    Sincerely,
    Allan
    Go Ahead. Use Us.
    May 27, 2008 | Cameras
    I can only take 8 pictures. I put in a sd 256 chip thing, but internal memory is still full after only 8 pictures.
    can you change where the pictures are being saved too?
    read instructions, but im pretty sure you can change whether the pics are saved to the internal memory, or the card.
    Mar 16, 2008 | Kodak EasyShare C613 Digital Camera
    Nikon Coolpix S9100 12.1mp Digital Camera red 26249 Logo
    85,070 people viewed this question
    Top Nikon Cameras Experts
    Ric Donato
    pictureman4u
    Geoff Hone
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
