Question about Sony STR-DE405
Sony str de405 receiver...was working fine, now no sound
The receiver was connected to an ipod, working fine, when the breaker was accidently turned off then back on , and now the power comes on the display, but nothing comes out the speakers
I have a problem with vintage reciever Sony STR-11L. Power transistors were replaced and I dont know what were original ones. Sound is no good and radiator is hot-I think problem is in replacement. Can anybody help me with?
Posted on Jan 21, 2010
SOURCE:
Will not turn on, is therd a fuse I can replace?
There are fuses for the radio in the fuse box and also behind the radio itself.....check fuse box first!
Jun 06, 2015 | Sony STR-DE405
Why will my receiver not turn on
Power supply regulator fault. Check the fuse. If it is found blown up, contact any service technician; before replacing it an other one; because, without any reason the fuse won't blown off. You should find out and rectify the fault, before replacing an other fuse. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
How to hook the speakers with the sony STR-DE405
I have a Sony STR-DE405. The front speakers are connected to the FRONT SPEAKERS A terminals L and R. If you are installing surround speakers, they are connected to the SURROUND SPEAKERS terminals LR, RR, and center (front). This model does not have an active wooker connection. The FRONT SPEAKERS B terminals are for connection of a second set of front speakers
Dec 09, 2012 | Audio Players & Recorders
I have a sony str-de 405 recevier . how do i connect a subwoofer to it .....
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DE405-Receivers-manual/id/387bh944/t/2/
and refer to the manual that should have come with your unnamed subwoofer.
Mar 21, 2011 | Sony STR-DE425 Receiver
How do i connect an ipod to my sony str-de310 receiver
Connecting to a home stereo
  1. For most home stereo systems, connect iPod to your amplifier's sound input using a 3.5 mm mini stereo to RCA adapter cable.
  2. Adjust the volume on iPod to less than half to prevent overdriving your amplifier. Adjust the listening volume using your stereo's controls.
    Note: Depending on your stereo, iPod may need to be set higher than half in order to get a proper volume through external speakers.
http://support.apple.com/kb/ht2167
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 12, 2011 | Sony STR-DE310
How do I connect my ipod to my Sony STR-DE585 receiver
Use analog audio cable with jack connector on one side (to the iPod) and 2 RCA connectors (white/red) on the other end for the analog inputs of receiver.
Feb 07, 2010 | Sony STR-DE585 Receiver
Input from IPOD - I want to play music from my IPOD through my Sony STR-DE1075. I have an IPOD line out adapter. cannot figure out which input I should be using.
Any input as AUX , DVD or Tape will work fine ..whichever you connect.and/or available...But please do not ever use the "Turntable" input...make sure volume of IPOD is half way open as listening earphones not max..good luck..
Jan 07, 2010 | Sony STR-DE1075 Receiver
Sony TC-WR670 eject wont open deck
I had the same problem. You probably have to replace the rubber belts.
Dec 02, 2009 | Sony STR-DE405
"Protect" flashing on STR-D665 Receiver
Check if you connect corectly the speakers wiresnand if they are right connected the audio amplifier Ic are damaged
Nov 28, 2008 | Sony STR-D665 Receiver
483 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
