Canon PIXMA MX310 All-In-One Printer Logo
Anonymous Posted on May 14, 2009
My copier and printer work just fine but cannot get the scanner to work at all...I have followed the instructions precisely. Isobel
Ekse
Level 3:
  • Canon Master 13,435 Answers
  • Posted on May 14, 2009
Ekse
Canon Master
Level 3:
Answers
13435
Questions
82
Helped
3983129
Points
38023
Okay so the copy and print function works, but you can't scan to your computer?
Are all the drivers installed?
all the drivers etc are available at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2613&modelid=15603#DownloadDetailAct
To test scanning, follow these steps
press start and select run to open run menu OR
hold down windows key and press R to open the run menu
in run type: mspaint and press ok
in the paint program that just opened click File and select from scanner or camera, scan a page and get back to me with results.
make sure the drivers are all installed. If you can copy with the printer (without the use of a computer) then the printer is perfectly fine and it comes down to settings or missing drivers on the computer.
Ekse
My cannon 340 pixma printer/scanner is not scanning the whole page. It prints, and copies fine. It's the scanner that is the problem. If it matters My OS is an iMac. How do I correct that? Thanks
This sounds like a software driver issue. look for the software at the printer manufacturer's website. After you download the software, follow the included installation instructions.
Hope this helps.
My scanner has not worked since i purchased this printer. My error is as following: CANNOT CMMUNICATE W/SCANNER. cable may be disconected or scanner is turned off. CODE: 2,155,0. PLEASE HELP!!!!
Follow these steps:
1. Unplug the printer.
2. Uninstall the driver.
3. Re-boot your computer.
4. Then reinstall (from the CD if you still have it)
5. Follow install instructions with printer.
6. Test the printer/scanner/etc.
7. If this doesn't work... go to canon's website and download the most current driver for the printer. then redo these steps using the downloaded driver for step 4.
If this doesn't work, return the printer if you still can.
Scanner won't move, just clicks
I had the same problem. I just followed the solution here:
http://www.fixya.com/support/t6219664-hp_6110
for "scanner failure". there are instructions on how to remove the document feeder and scanner glass, clean the glass and lubricate the rod that the scanner travels on. I followed the procedure and my printer/scanner now works fine.
1helpful
Paper won't load
Try cleaning the paper feed rollers with a cloth dampened with just plain tap water.
Printer and copier work fine- scanner says USB not connected.
HI,
Please get back to me with the following details to assist you further.
  1. What is the printer model?
  2. What is the OS you are using?
  3. Have you installed full feature software?
1helpful
Printer and coper work scanner does not with the new vista. Can it work with vista
Click Here and Follow the Step by step instruction.
Hope this help. Please Rate My Response! Thanks!
PREM
2answers
Hp3030 allin one printer scanner drivers not working in xp-sp3
Please download latest driver from following link,install it and then check.
Click Here To Download
Thanks
Scanning function doesn't work
If it copies fine, then it IS scanning. If you are trying to scan to your computer then you will need to open the program and follow the instructions.
Scanner not working
Please open HP director from Start - All programs - HP .
Click Scan document to scan.
You can scan by following steps :
For Windows XP:
To isolate the issue I suggest you to try scanning from the Windows Image acquisition(WIA) wizard on the computer.
Follow the below steps to Scan using WIA
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
Waiting for you reply.
Thanks
old marine
old marine
ZJ Limited
ZJ Limited
