SOURCE: Broan Nutone Allure lll light problem
The problem is the little lever in the socket. Turn breaker of fan off, grab a flat head screw driver and lift the little lever slighty like a 45 deg angle. If not the replacement socket assembly is
part # R111630 comes in a pair. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
SOURCE: Broan Allure QS3
The Problem is the wiring. Take the 2 screws retaining the metal plaque off underneath the filters. You will see the wires leaving the motor going into a "molex" plastic connector which connects two another set of wires going to the control board. Check to see if the wiring colors match from side to side of plastic connector. Ive only seen it happen once but it was exactly that. I do service calls for broan & Nutone
Jean-Marc
SOURCE: Broan Allure II
The problem is definetly the control board.
Part# R111638=$110.00. I do service calls for broan.
Inventex.com
SOURCE: WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: my broan allure turns on by itself
Isn't it suppose to turn on automatically? The broan has a heat sensor!
