My microwave is working but the turn table is not turning
next time send the brand name and model number,when you go to work on a micro wave unplug it,even if you change a bulb on it,i've seen people change the bulb without unplugging it and cook the computer board,on the bottom there's a motor that turns thee turn table,drop the bottom panel of the micro wave usually like 6 to 9 screws and on some there could be an access panel just for the motor,unplug the old motor and remove screw or screws,pop off the cover inside the microwave where the glass turn table sits on and,put the new motor in and put it back the same way you took it apart,it's pretty easy to do.go here put your model number in and find part number
https://www.searspartsdirect.com/part-number/241700104/0046/253.html?pathTaken=partSearch&q=241700104
