The starter is located on the lower side of the motor. Disconnect negative battery cable. Raise and support vehicle. Remove flywheel cover (s). Disconnect starter solenoid wiring. Remove starter mounting bolts. Remove shims and note arrangement for reassembly (if equipped). Remove starter assembly. To install, reverse removal procedure. Ensure shims are installed in original location (if equipped). Tighten fasteners to specification. Starter Bolts 35 Ft. Lbs, Flywheel Cover Bolts 89 Ft. Lbs, Positive Battery Cable-To-Solenoid Nut 89 Ft. Lbs, "S" Terminal Nut 37 Ft. Lbs
Starter located on the engine, from under car look between engine and radiator, where engine connects to transmission, that is the starter. Check links below, press the helpful button Chevy HHR starter location and removal
starter solenoid is usually located on the starter on all GM products. There is also a starter relay in the fuse box located under the hood of your particular vehicle.
The location of the starter is as per the car engine.If its 4.5 liter then starter is located on front bottom of the engine.And if its 4.6 liter engine then starter is located under the intake manifold.And On the 4.9 liter the starter is located on the bottom side of the engine. ------------This will help.Thanks.Helpmech.
The starter is usually located on the side where battery sits. The best way to determine where the starter is located, follow the positive cable toward engine. The positive wire usually connects to the starter. Occasionally, the starter may be located on the opposite side of engine. In either case, simply following the positive cable will lead you to the starter.
The starter solenoid is located on the starter. It looks like a miniature version of the starter which is attached to the starter. The starter relay, however, is located in your engine compartment on the passenger's side under the black box which also houses your cars main computer. This black box is located towards the back of the engine compartment (close to the windshield) on the passenger's side. There are 4 philips head screws which hold it in place.
