If you forgot your password and/or want to reset the router back to the default settings:
Step 1 Power the unit off by unplugging its power adapter.
Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure.
Step 3 Power the device back on by plugging it in. Continue to hold the reset button.
Step 4 Watch the lights on the front of the gateway. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button.
The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, recycle the power on the gateway.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure.
The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case). The default IP address is 192.168.0.1.
BEST OF LUCK
