Kenwood ProTalk UBZ-AM14 (14 Channels) 2-Way Radio Logo
E
ELLIOT BROWNE Posted on Dec 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Manual FOR UBZ-AM14 - Kenwood ProTalk UBZ-AM14 (14 Channels) 2-Way Radio
sadiq muhammad
Level 2:
Champion:
  • Kenwood Expert 228 Answers
  • Posted on May 28, 2019
sadiq muhammad
Kenwood Expert
Level 2:
Champion:
Answers
228
Questions
0
Helped
81175
Points
438
How many miles will the Kenwood UBZ-AR14 transmit?
Two miles under perfect conditions over flat clear terrain.
I have a ubz-lh14 and all it does when switched on is beep every couple of seconds.
The Beep indicates low Batt. But if you charged the battery then clean the terminal connections on the battery and the radio. If still no good then you need a new Battery.
My ubz-lf14 cannot turn on,if turn on,can only hear but cannot reply ptt,then turn off automatic..why this happen?what I can do DIY for solve this thing?
You are receiving but cannot anser. Your Battery of Radio is not fully charged. You charge the Battery or replace with new one. If your problem not solve then it is Power Module Fault. You replace the PA from expert person in Radio.
Hello,I have four walkie talkie brand new from Kenwood, UBZ LF 14, and they work in the PMR band. Now I'm living in Italy and the PMR band is not allowed for family use by the Government The family...
Elio:
Your local Kenwood rep is correct for a couple of reasons:
1. The cost to modify your current radios to operate on the Italian band would be higher than the price of new radios.
2. Operating modified radios would be a violation of Italian laws.
Bill B
Need owners manual
Hello there, I think your best bet would be to contact kenwood customer support/distribution Fax (310) 537-8235 for your manual, or they will advise what path in their division to take l'm sure,
good luck --John.
AM14 tank heaters--when are they energized?
How hot is the wash temp?It should be 150-165 degrees.The model is an am14 not an am15?I'm hobart tech and repair these units weekly.Let ne know.
I need help
This sounds like one of those situations where the radios will need to be serviced at a local kenwood dealer or depending on the value of the radios you might want to junk them. The average radio repair runs $75.00 to $90.00 just for the labor. The other option if so inclinded to do so would be too order the service manual for this radio and attempt to complete the repair yourself. I don't know your skill level at electronics. I wish I could help you more.
Patrick
1helpful
Am14 initial fill
lift **** basket out and lift out samle stailees plate drain and look for stailess probe coming out of side of tank half way down there should be a white pprobably yellowed plastic ball it is a float they get old and fill fith water and don't flote telling maching I have no water keep the water coming. the float is sometimes even missing fell off andf thrown out. 10 bucks and a clip your off and running. call hobart its 110.00 and your off and running.
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
Ngoro
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
