E2 Error usually indicates that the treadmill is overloaded and applies to various models like TR150, TRX1000 and TR 200. To fix this problem, check if your treadmill motor is overheating. Signs of an overheated motor include; grinding noise, motor produces a burning smell and inconsistent operation speeds.
Reddit · r/fixit3 comments · 4 years ago
Hi i have a reebok one gt30 treadmill bought in 2016. Recently at ... Start googling error codes and find out what E2 means. Upvote 2
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
The True600, 700, 725 and 750 seriestreadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
The error messages that may be displayed by the built-in diagnostics are as follows:
E1:INCLINE
This means that the incline is moving when it has not been commanded to.
E1:MINIMUM
This is a minimum incline calibrating error that can be cleared by calibrating the incline.
E1:RANGE
This means the difference between the treadmills zero position and maximum incline is not sufficient.
E1:STALL
This means that the incline is not moving when it has been commanded to.
E2:OVERSPEED
This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
E2:CAL
This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
E3:EEPROM
This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
E5:SENSOR
This error occurs when there is no speed or RPM feedback detected from speed sensor.
The service messages that may be displayed by the built-in maintenance reminders are as follows:
S1:LUBE
This service message displays when it is time for inspection of the deck lubrication system.
S2:CLEAN
This service message displays every 500 miles and is your prompt to clean the treadmill.
S3:MOTOR
This service message displays every 2500 hours and is your prompt to check the motor brushes.
This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
E2= Belt speed loss + E4 = Belt over speed. 1) You must adjust the speed sensor, face to face with the magnet (tha go in the outside of the motor) 2) You must use the calibration software please see you owner manual or go under the Hood and read and take the steps indicated in your treadmills.The software will be adjust this problems, with easy diagnostic!3) If you do not have the owner manual download for free: www.iconservice.com, give your model, etc sincerely. Merry Christmas. ernesto cuadramanagua, nicaragua.
an E2 is a speed error code and the others all just tell me you have a friction problem-elevate the incline up all the way,without mtr working,push yourself off backwards-did you use muscles in arms/lower back? was it diffacult? thats friction,like rubbing hands together for long time. Result, no lube under walking belt- replace mtr,controller,walking belt- cost- a new treadmill
I believe E4 on ths 730si means that the speed of the motor the sensor is detecting is greater than the set speed. E2 would be the opposite. I believe there is a way to calibrate the speed. Look at the smaller motor controller board.
