What should i do to make all the apps that i want works on my iPhone, how do i make them properly installed?
SOURCE: unlocked iphone can't receive 1.0.2 update
ok this is wat i suggest just update to 1.1.1 its same thing this is also 4 any1 that wants to unlock there iphone. download firmware 1.1.1 place it on your desktop connect your iphone 2 your pc. now hold the home button and the sleep button at the same time until u see the connect to ituners or usb and cd depending on what firmware you have this is restore mode. go to itunes it will say your iphone needs restoration hold shift click restore an window will open up 4 u to chose wat file ul be using for restore use the firmware 1.1.1 that i told u to download it will restore your iphone but will get and error at the end. dont worry after that open up ibriker and click on boot iphone and ul be at the activation screen
SOURCE: iPhone rebooting automatically.
Remove the offending apps. Make a backup of your phone. Restore the iPhone to factory settings and the restore your backup to the phone. If that doesn't work you may have a hardware issue. If apple doesn't help you can send it to iPhone 3GS Repair or do it yourself there is a guide that shows you how to disassemble the phone at iPhone Repair Guide.
SOURCE: update ios 5.1 with jailbroken iphone 4s
Not possible on 5.1 for 4s apple stopped writing the code for 5.0.1 already so a downgrade ain't happening bright side though any day now according to Twitter
If you are having trouble logging into Facebook from your iPhone you should first check the login information through the web browser, which you can try either through Safari or on a computer.
The Facebook iPhone App has been designed to simply log in your information automatically once you have entered it, so that you do not have to actually enter your account information over and over again. If this information has been entered incorrectly it may cause trouble logging in automatically and you may just need to re-enter your account information so that automatic log in can continue.
Though most iPhone apps have their own app-specific settings in the iPhone Settings area, none of the settings for the social networking iPhone apps have anything that would give you trouble logging into them. If you believe that you are having trouble logging into social networking iPhone apps because of the lack of available Push Notifications then you should check the settings for each individual app as this is likely the source of the issue, and not a problem with logging in.
