Question about Bertolucci Diamond Watch for Women
I don't know how to set the date on my bertolucci watch
  • Lisa Darling
    Lisa Darling Dec 26, 2013
    Thank you!!!!! You solved the problem. Yahooooo!
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Having trouble pulling out the crown, or nob? You might have a screw down crown so you need to unscrew it going downward before you even can pull out the crown to set.pull the crown out once for the date and twice to set the time.
Posted on Dec 26, 2013
SOURCE:
My watch is turned on, but I need to set the time and don’t know how!
Setting the Time Manually
  1. Hold the touchscreen to view the menu.
  2. Select > Manual.
  3. Select or to adjust the time of day and date.
  4. Select to confirm each setting.
https://www8.garmin.com/manuals/webhelp/vivosmart/EN-US/GUID-4503FF46-4FFC-493A-BCBD-C2102F2A5AAE.html
Mar 14, 2018 | The Watches
I have a casio 4798 model watch and the date changes at 12 instead of 24. anybody can help me? thanks
I don't know the details of your watch (I couldn't find it on their web site) but this problem commonly occurs on analogue watches, so on the assumption that this the case, the remedy is as follows:-
Wind your watch on 12 hours; this will align midnight on your watch with midnight; (you may have to re-set the date if it changes while you are doing this).
Jul 13, 2011 | Watches
Don't know how to set the date except by winding the time dial repeatedly past 12 to get to present date--must be an easier way
I presume that you are winding the watch 24 hours to change the date.
You can shorten the time it takes to change the dates in the following manner:-
Wind the watch until the date changes, then turn it back until it passes 12 again and then turn it forward. Each time it passes 12 the date should increase by a day.
You may have to experiment to find how far past 12 in both directions to get the date to change.
May 12, 2011 | Baume Et Mercier Baume & Mercier Classima...
Watch is missing user guide, how do I set the Honora 3ATM watch
To set a basic wristwatch, simply pull the crown (the winder button at the 3:00 position on 99% of watches) out gently - it will click into adjusting position. Wind to send time and then push back in again.
Variations on this are: If you have a watch with date display, the crown will have 2 positions, the first click will be to set the date and the second click (fully out) is to set time. If you need to adjust the date, I suggest you wind the date to the day before you need and then use the second click to wind the hands to the correct date. This way you will be able to know if you have the hour at a.m or p.m position and avoid it have the date changing during the day instead of at night.
One last variation for wristwatches is a screw down crown. Some water resistant and sports models incorporate an added feature whereby the crown is threaded so it can be tightened down to avoid water entering - the most common place water gets into a watch! If you have one of these, you simply need to screw the crown anticlockwise until it pops out and then refer to the instructions above. Don't forget to push and screw the crown back in clockwise when you are done
Apr 30, 2011 | Honora Watch
Cant set wrist watch
Apr 07, 2011 | Movado Juro 0605023 Wrist Watch
Coil shotage of Bertolucci watch
mcdevito75 here, Sounds like you need a new quartz mechanism for your expensive watch, contact your watch company online, ----- Your watches name plus.com or check with any jeweler, watch repair in any large city in India. A new quartz mechanism and work is expensive depending on the value of your watch, it may pay just to replace the watch.
Jun 24, 2010 | Bertolucci 18k Gold Diver Watch for Women
I have a stainless steel Bertolucci watch,it stopped working does it have a battery? ,plus i would like to sell it,i live in the st louis area
If you go to their web site and look at their "collection", you should be able to find your watch and be able to find out what you what to know.
Web site http://www.bertolucci-watches.com/en/collections.php
If your watch says "quartz" on the front, then it is battery driven, if it says "automatic" then it is a spring driven self winding type (which stops when not being used).
May 07, 2010 | Bertolucci Vir Mini Steel and 18k Gold...
What is the best time of day or night to set the date on Beringer watch Brand name not listed
If it's a mechanical watch don not set the date between 7pm and 2am to avoid damage to movement.
May 03, 2010 | Watches
Can I remove the back of my bertolucci watch myself and replace the battery?
The method of removing the back of a watch varies from make to make. Often the question is how can I get it back on!
Unless the watch has an obvious battery cover (a small round cap which can be screwed off), it is much safer to take it to a watch shop to replace it for you.
They have all the tools, a stock of batteries and will will do the job a few minutes.
Jan 24, 2010 | Bertolucci Vir Mini Steel and 18k Gold...
Bertolucci Diamond Watch for Women Logo
163 people viewed this question
Top Bertolucci Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Bertolucci Watch Expert? Answer questions, earn points and help others
