Question about Mitsubishi WS-55819 55" Rear Projection Television
Mitsubishi wd-65733 won't turn on
Green light turns on then after a few seconds the light turns red and the tv shuts off
SOURCE:
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Posted on Dec 18, 2007
SOURCE: yellow status light on mitsubishi wd-65733 tv
When tv goes out, press the menu and input buttons. The green light will flash with a 2 digit code.
Posted on Oct 23, 2008
rob52078
  • 40 Answers
SOURCE: When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Posted on Mar 13, 2009
  • 979 Answers
SOURCE: when i turn on my 64inch mitsubishi wd 65733 tv it
Good Day Judy, hi, as i see it, your 64 inch TV is on standby mode, this occurs when the Power Supply Board, (inside your TV that supplies good power from the main 220/110 v line) detected an overload, this over load can be on the power board itself or from the main board that controls the LCD screen, controls and sound, (kinda technical), replacement of the power supply board is necessary, (this symptoms are common for LCD tvs), since its a 64 inch TV, its kinda hard to handle, better call for help. Call your dealer first, ask for warranty, if no warranty, then ask for service. you can ask other dealers if they have service too. Get the best bargain. thats all. = )
Posted on Feb 02, 2010
jmgldsmth
  • 2005 Answers
SOURCE: tv shutdown
check your lamp door interlock switch.
Posted on Jul 31, 2010
Mitsubishi 65733
CONTACT MITSUBISHI TECH SUPPORT, THEY SHOULD BE ABLE TO GIVE YOU AN IDEA OF WHERE THE PROBLEM IS WHEN YOU TELL THEM THE ERROR CODE, THEN LOCATE A HONEST TV TECH FOR A ESTIMATE.
Feb 02, 2014 | Mitsubishi Televison & Video
65" 1080 mitsubishi tv model# WD-65733 wont turn on
It is probably the wiring. Try buying a new power cord.
If not than it is just malfunctioned.
Contact Mistubish
http://www.mitsubishi-tv.com/contact
Nov 25, 2012 | Mitsubishi WD-65733 65" HDTV
Starting light flashes green, and then red. Turn off and on several times.
Possible lamp but:
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Nov 07, 2012 | Mitsubishi WD-65733 65" HDTV
Turn on set, green light comes on then hear click and red light appears. changed out lamp, tv still wont come on. Power supply?
Make sure all fans are running,defective Fan can cause this,also Ballast board is what powers Lamp on. If ballast is bad Lamp will not light.
May 31, 2011 | Mitsubishi WD-65733 65" HDTV
Tv shutdown
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
''Mits'' WD-65733 blinking timer light
The green LED is blinking because there is fault in the TV you will have to take to a technician to determine the cause.
SUPER8
Nov 24, 2008 | Mitsubishi WD-65733 65" HDTV
Yellow status light on mitsubishi wd-65733 tv
Jul 26, 2008 | Mitsubishi WD-65733 65" HDTV
Mitsubishi WS-55819 55" Rear Projection Television Logo
63 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
