Question about Yale Locks & Locksmithing
Crack combination lock - Yale Locks & Locksmithing
How do I reset the word lock bike lock when I forgot the word I used last.
You can't reset it if it is currently locked together. You have to try to "crack" the combination.
184 WordLock Combination AVOID THIS LOCK
Wordlock pick
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Apr 14, 2017 | Cycling
Forgotten Code
http://lock-picking.wonderhowto.com/how-to/crack-combination-bike-lock-under-30-seconds-160666/
Basically, pull the pin and find which rotary wheel binds. rotate it until it unbinds. Repeat with remaining wheels.
Oct 29, 2013 | Kensington ClickSafe Master Coded Cable...
I can't open my safe. how can i know the combination of my safe. it is a normal safe.
Sorry, but you can't, That's why it's called a "safe".
If you lose the keys or the combination then the safe must be cut or drilled open. Some specialist locksmiths may be able to pick the lock or crack the combination, but it usually takes so long and costs so much that destructive entry proves to be cheaper. Many safes also have unpickable locks and uncrackable combinations anyway.
Jul 20, 2011 | Locks & Locksmithing
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Oct 28, 2009 | Sentry Fireproof Safe
I lost the combination to my APC PNOTECL5
Call customer support. If they can't do anything, look up combination lock cracking on the internet.
Jun 03, 2009 | APC PNOTECL5
Locks & Locksmithing Logo
133 people viewed this question
Top Yale Locks & Locksmithing Experts
john h
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Yale Lock and Locksmithing Expert? Answer questions, earn points and help others
