Question about Casio FX-115ES Scientific Calculator
Any way to make decimal answers the default? (casio fx-83ES)
Been struggling with this calculator (casio fx-83ES as mentioned) for a few years now, and although I can get decimal answers by pressing the S<=>D button, I was wondering if there was a way of making this permanent. I hate having to press the button every time. Fractions are no use to me! (eg 7 divided by 2 will give 7/2 instead of 3.5 like I want it to give)
Any help would be appreciated!
  • 2 more comments
  • Anonymous May 18, 2009
    Can not get the answer in decimal in first go. Instead it is in fraction and the help was not enough for me
  • megan_637 May 26, 2009
    same problem
  • mamta583
    mamta583 Nov 28, 2016
    good the internet mainly because well as allows kodidownloadapp its assembly. Below happen to be some of the Pre-requisites nice.
  • Collins456
    Collins456 May 10, 2017
    almost anything that runs Windows 10. kodi download One of Kodi's biggest toughness is just how very easy it is to use.
  • 4 Answers
You want a line output
Shift > Mode > 2:LineIO or on the graphics one its sometimes 10:LineO etc.
look for something with line in it
Steve :P
Posted on Aug 28, 2009
    Sergeant:
  • 322 Answers
Yes there is, press shift mode, then line 10. It will make it permanent.
Posted on May 14, 2009
If you want to keep the natural display qualities, (ie the fractions look like fractions, exponents loook like exponents etc.) clear your calculator(shift-9, 3) then just hit the S<=>D button above the delete button to convert to fractions/decimals
Posted on Jun 09, 2009
    New Friend:
Apps, and a great deal more. Keep checking https://itutuhelper.com/tutu-helper-apk-download/ you that this is third-party setup, tap Allow.
Posted on Jul 11, 2017
SOURCE:
How do i change from getting answers in fractions to decimals on a casio fx-83ES?
Change the Input/Output Mode to LineIO. Press [SHIFT][MODE] and select [2:LineIO].
Aug 07, 2011 | Casio fx-300ES Calculator
I have a casio fx-83ES. I want the calculation to always give me decimals, it currently always gives me fractors, how do i change the setting so that I get decimals only ?
To convert a single result to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select LineIO mode.
Sep 27, 2010 | Office Equipment & Supplies
How do i get my casio fx-115 es calculator to show answers in decimal form?
To convert a single result to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select the LineIO mode.
Sep 21, 2010 | Casio FX-115ES Scientific Calculator
I have Casio fx-83ES. I'm using it in Mode 2 - LineIO, so answers are always displayed as decimal. However if i enter the sum 3.33 divided by 1000, the answer is displayed as 3.33x10^3 whereas really i...
You can configure it as you wish. Press [SHIFT][MODE] to access the (SETUP) configuration screen, then select [8:Norm].
You will be prompted to choose Norm1 or Norm2. To help you find out which is more appropriate to meet your concerns, I am inserting a screen capture from the manual.
Apr 05, 2010 | Casio fx-300ES Calculator
CASIO fx-83es
Press [SHIFT][AC] (ON).
Hope it helps.
Oct 20, 2009 | Casio fx-300ES Calculator
Converting decimals to degrees on a casio fx-83es calcualtor
if you mean degrees like the degree/minute/second thing: lets say you have 24.12 there is a button that has a dot, and 3 commas (it's located next to the negative button) that will convert that number to degrees. input your decimal, press the equal sign, and then press that degree button and it will convert 24.12 to degrees, minutes, and seconds. the solution is 24 degrees, 7 minutes, and 12 seconds.
Jan 11, 2009 | Casio FX-115ES Scientific Calculator
Casio fx-83ES
Press Shift and then In
Dec 08, 2008 | Casio fx-300ES Calculator
I have a casio fx-83es calculator.If I type in for example 87.67 34.56 , the answer will display as a fraction. I am aware how to get it in decimal form after hitting certain buttons but, As I am...
Doubt you're still having this problem as its been months....figured id post for people who stumble across this from google.
Click on the shift button in the top left, then select the mode buttom (second from top right), then press the number 2. This should switch the calculator onto linear and will give you answers with decimal points.
Regards,
hopper84
Jun 26, 2008 | Computers & Internet
Casio fx-83ES
there is a button SD close to AC button, standard - decimal try it .......or
shift+mode format math IO, change it to the other option
Jan 02, 2008 | Casio fx-300ES Calculator
Casio FX-115ES Scientific Calculator Logo
6,689 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
