Hi, My iriver is not working at all. Earlier it was working but i didnt used for some time and i am not able to turn it on as well as its now accepting the driver while connecting to the pc/laptop. I lost the cd which was received with it. what to do, Please suggest. Will i be able to use it again.
SOURCE: iRiver MP3 Player Not Inisializing
If you haven't already I would try an emergency connect. -First perform a standard reset as you did before (press rear button for 20GB or disconnect & reconnect the battery for the 5/6GB versions). -Leave the unit turned off, but connect it to your computer's USB port. -Hold down the "o" button and then press the power button for a second to power on the device. -Do not release the "o" button until you see a message such as "emergency connect" or "mass storage" on the player screen. I beleive the message has changed with firmware versions, but it should be something similar. -If this works it should be detected by your computer as an external drive. You should have access to the files. -I would remove all music files from the device and then use the iriver plus software to restore system files. -If you manage to get to this point I would install the newest firmware available for your model of H10, found at the iriver site. The newest firmware adds a lot of functionality, speeds up player response significantly, and fixes many bugs as well.
SOURCE: driver
I found a Manual to help & a couple of driver links hope this helps... www.iriveramerica.com/download/iFP-300-Eng-Int-030403F.pdf www.driversforwindows.com/iriver_ifp_380t_firmware_1.22_21557.htm drivers.softpedia.com/get/FIRMWARE/Iriver/Iriver-iFP380T-firmware-122.shtml
SOURCE: iRiver H340 firmware
with the hex file hold the navi button for a few seconds; you get four options select the general one then you will see an upgrade firmware option. select this the hex file on your player is your firmware it will then go through the upgrade process. don't touch while this is happening. it will turn off when done. then thats it. Be careful the version v1.30 will get rid of the video option go with v1.29 or less
SOURCE: I need to restore the system files for my H10 Iriver MP3 player
System Files Missing
To restore
the system files,
connect H10 to
recovery tool.
