Samsung UA40D6000 40 inch Full HD 3D LED Multisystem Smart TV FOR 110-220 VOLTS Logo
P
Paul Verdolino Posted on Dec 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to display the keyboard on my Samsung Smart TV using the remote control that came with it. How do I get it to come up? And, how do I put the browser on the tv in tab mode so I can enter from the keyboard?
windsorguzzi
Level 3:
Master:
  • Master 796 Answers
  • Posted on Dec 15, 2013
windsorguzzi
Master
Level 3:
Master:
Answers
796
Questions
Helped
189380
Points
2084
Download the manual from the samsung website.
However on my Samsung 6800 tv the browser cannot do tabs.
The only keyboard is one where you move the cursor around with up/down/left/right buttons on the remote controls.
Testimonial: "Thanks very much for your help."
I can't sync my keyboard with my lg smart tv
Select Smart Home ( ) > Internet . Go to a search engine. Select the search field to display the QWERTY keyboard at the bottom of the screen. Select on the QWERTY keyboard or, with the QWERTY keyboard displayed, press the Voice Recognition ( ) button on the Magic Remote Control .
Samsung hg40ee470sk secret menu?
Samsung Smart TV hidden secret menu allows you to do a factory reset and also connect some Bluetooth devices which you were unable to do before. Be careful while fiddling with these options as I cannot take any guarantee if you spoil the TV settings. The Samsung Smart TV I used in the video is Samsung F4500. The secret menu will not open with a smart remote. You may buy or borrow the original normal rectangular Samsung remote to access the secret menu but I am not so sure that will work.
Here are all methods to access the secret menu of different Samsung smart TV:
Method 1
Put the TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV on standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Method 7 for Smart TV RU7100, NU7090 Series 7 (suggested by viewer Caleb Harch)
How to repair a samsung Led tv model ua 50f 5500 amxxs. When I switch ON. it just show the flashing SMART Logo.It will not go to the tv channel.
If the TV displays the menu or Smart Hub when you press the button on the remote - the TV is on, it's just displaying a black screen. Change the Source on the TV to another input. See the page on Samsung TV has No Picture for more troubleshooting steps.
Depending on the TV, there will be a Jog Controller or TV Control Stick that will allow you to access the TV menu and change the source. Use the control on the TV to select an option - toggle it left or right to see if anything appears on the TV.
If the control menu appears on the screen, the TV is on but not displaying any input. Check the connections or change the input source on the TV. If the controller button works on the TV, but not the remote, check the batteries in the remote control.
Unplug the TV from the power source and leave it for a minute or two. Reconnect the power cable directly to the wall rather than a surge protector. If the TV Standby light appears - the TV is receiving power. If the Standby light still doesn't appear, please get in touch to organise a service.
How do i use my keyboard on my remote?
You have to pair the querty side of the remote. Go up to your samsung smart TV 8 inches or less to pair. Press SYM and TAB at the same time. You should notice on the screen that it states "Pairing." Your TV should confirm. Make sure your tv is on and it is set to accept Bluetooth. The keyboard will load up when you press a key. Follow information on TV screen. Some applications like Netflix do not work with the remote. You can use your query side when you press on an app. If a screen pops up like for web browsing just type like a keyboard.
Bt error
Put in fresh batteries. You have to pair the querty side of the remote again. Go up to your samsung smart TV 8 inches or less to pair. Press SYM and TAB at the same time. You should notice on the querty screen that states "Pairing." Your TV should confirm. The keyboard will load up when you press a key. Follow information on TV screen. Some applications like Netflix do not work with the remote. You can use your Querty side when you press on an app. Scroll to any app. If a screen pops up like for web browsing just type like a keyboard.
2answers
My Samsung remote bn59-01134b only works on one side is it locked or broken
It will be best to contact the service center to get it repaired. There is nothing a user can do in this case.
AK59-00123A tv codes
0387.0194,0162,0564,0291 are the codes to check. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
1helpful
How to use the samsung BN59-011348 remote control
You have to pair the querty side of the remote. Go up to your samsung smart TV 8 inches or less to pair. Press SYM and TAB at the same time. You should notice on the screen that it states "Pairing." Your TV should confirm. The keyboard will load up when you press a key. Follow information on TV screen. Some applications like Netflix do not work with the remote. You can use your query side when you press on an app. If a screen pops up like for web browsing just type like a keyboard.
3answers
Top Samsung Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Samsung Car Audio and Video Expert? Answer questions, earn points and help others
