Hi, We have a Beko DSFS 1531 W and both the rinse aid and salt lights are red. We have just changed from tablets (with the rinse aid included) to powder. How do I get them sorted? Reading the manual re: adding salt it says make sure 1litre of water is added. Do I pour water in as well as the salt? Have never added rinse aid so please advise. Thanks, Helen
Rinse aid and salt are not necessary if you use powder that is similar to the tablets. The lights are warning you that you havent added them, you know that so ignore the lights. If you live in a hard-water (limescale) area salt can be used as well as tablets or powder to make the water kinder to the machine, but most people just use tablets without rinse-aid or salt.
SOURCE: DISHES COVERED IN WHITE POWDER
To check on the source of the white powder (calcium?) soak some dishes in vinegar to see if this cleans them up nicely ... or if the 'white powder' is actually permanent etching. You may have very 'hard' water and will need to deal with that with a water softener or additives.
Read the following article for a better understanding and try the vinegar test . (also ensure you are using dishwasher specific salt to regenerate your integral softener... assuming you have one)
http://www.dishwasher-care.org.uk/best.html
SOURCE: My Kenwood dishwasher KDW24FI/B has
lol is it a stereo or a kenmore, dishwashers dont use salt, but water softeners do
SOURCE: Salt lasts only a very short time in dishwasher
go 2 the inside of dishwasher ull find settings from 1 to 6 simply turn back
SOURCE: Brand new beko DE 2542 PW dishwasher won't start wash cycle
It sounds as if the d/washer is pressurising due to a blocked outlet drain hose.
Make sure that the drain for the dishwasher is actually clear take hose out of the drain outlet.On some of the Beko dishwashers they put a plug up inside the drain hose which has to be removed before use or if it is a new installation and it is draining into a "U" bend on a sink check that the little spigot that the hose is onto is actually open.They come from the plumbers merchants blanked if blanked then you have to cut the end off to suit size of hose.I hope this has helped.
Good Luck.
SOURCE: The "Rinse Aid" red light
The rinse aid light is just an indicator to let you know the rinse aid is low. You fill it in the container next to where you put the detergent. Just push the yellow button and the lid will pop up. rinse aid is more important on the newer miele dishwashers, as they dont have "active drying" like the older dishwashers did. They depend on the rinse aid to sheet the water off the dishes at the end of the cycle. They are designed this way to reduce energy consumption. If you choose not to use rinse aid, and you dont mind wet dishes at the end of the cycle, either disregard the red light, or fill the rinse aid dispenser with water to trick the machine into thinking it is full.
If you are not going to use the onboard water softener, you can turn it off. Refer to your owners manual, or call miele tech support at 800 843 7231 and they can walk you through the programming to disable the water softener. these are not fault lights, they are simply reminders that you need to fill the containers.
