HI,
you haven't mentioned clearly is the laptop in on state or are the batteries able to give power to laptop to start
try this solution if you have checked that the Ac Adapter is finr
take out the battery from the laptop and then plugin the AC adapter and then try to start your laptop
if your laptop starts without the battery by getting power through the Ac adapter, most likely your battery is Bad, get it replaced, if it doesn't start then it can be power circuit on the motherboard or the connectors you should get it checked from a technician.
If you think my solution was helpfull please do rate me
