You ran it dry at some point. Gas tanks collect crud and water at the bottom over time and this may have been sucked up into the fuel filter or carb. Clean or replace fuel filter, then remove and carefully strip apart and clean all parts of the carb be gentle with brass and any moving parts in the carb, clean with plastic tools.
Testimonial: "I posted this in the wrong forum, but here is a recap injector cleaner run through. No change. I did not want to take it apart and potentially ruin a $650 machine. So off to the local hardware store. They said that it is a chinese carb without settings for mixture. They suggested a new carb. Heck, if they are just going to replace the carb, I can try that. Disassemble (argh, have to remove take, to loosen bolts on bracket, to be able to remove shroud, to get to the bolts that hold the protector that covers the carb) and find that the mice have put acorns in the air box. Removed acorns and engine runs great!"
