Here is what the F06 code stands for
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down.
If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the
Motor ControlUnit (MCU), and between the MCU and the Central Control Unit
(CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
SOURCE: error code f06
hello fo6 means drive motor techometer error check wire harness connections between the drive good luck
shaun
SOURCE: i get an f06 and
F6
code is an issue with the motor drive tachometer.
Most often this is caused
by poor connections at the machine control or motor controller. Locate
the main machine control by removing the top panel and the motor control
by removing the rear panel. Remove each connector, one at time, and
reinstall. If this does not work, you likely have a faulty control.
E1
means that the thermistor is open and needs to be replaced.
The connections can be loose but the most likely cause of an E1 error is
a bad thermistor.
If you're comfortable and confident in your
do-it-yourself skills and have access to a volt/ohm meter you can check
and replace this part yourself.
For replacement parts - head on
over to SearsPartsDirect.com - PartSelect.com - or RepairClinic.com and
enter in your full model number for a full parts listing.
Hope helps.
