SOURCE: Switch has stopped working, kettle will not heat water
Hi Bruce or anyone else that has this problem.
I had this problem too and after pulling the base off I found that the switch was ok but the problem lay with the two bi-metallic thermal overload switches that are connected to the heating element. I managed to reset them both and now the kettle works fine. This can become an issue if you have accidently boiled the kettle dry once in it's life. Best of luck.
SOURCE: Hi Is it possible to buy
Replacement parts for Russell Hobbs kettles are available here:
http://www.directpartsandproducts.com/russellhobbs-kettles-c-55_1111_1212_1229.html?osCsid=5kjs46s0g583p8ljos3hp0pa41
I don't see your model so would suggest you contact then through their website:
http://www.directpartsandproducts.com/contact_us.php?osCsid=5kjs46s0g583p8ljos3hp0pa41
SOURCE: the handle fell off the kettle, how can I re-fix it?
If it do not have any obvious way to fix it (locking clips or screws) and it was just inserted on the metal part ..than you can use some kind of glue for plastic and fix it back again .a super -glue will work or a strong plastic adhesive .Clean both ends so that any grease to be removed...and apply the adhesive on the plastic end .. and than insert it to the metal end ..in such a way that the adhesive to fill the space and the excess substance will drain off when you press them together. leave them to react for a while without touching them ..be sure you choose a temperature resistant adhesive ...
