Joy Mangano 900-Watt Deluxe My Little Steamer&Reg; Anniversary Set Logo
A
Anonymous Posted on Dec 13, 2013
Need instruction manual for My Little Steamer
I did not get any type of manual with my purchase from HSN of the steamer. I'm giving as a Christmas gift & need a booklet ASAP!
1helpful
What is wrong with my Eureka enviro steamer?
It is limescale. Basically your steamer takes water and boils it dry and turns it to steam. Any minerals like calcium in your water is left behind as rocks or flakes.
It should be descaled once every couple of years. You can do it fast with a product like CLR, or overnight with white vinegar. Fill it up and leave it, next day, turn it on and get it hot, but not boiling. Turn it off and leave it to cool. Empty and rinse 3 or 4 times.
Home touch garment steamer model ps-280 wont turn on
If it were left on its possible that the element that heats the water has burned out think blown light bulb have your Mr Test it with a ohm meter to see if the circuit is open
Home Touch PS 250B
Best way is to contact manufacture and ask for part dealer near your location
My hand held little steamer will not get hot. switch comes on, but that is all it does
If the switch isworking then the only possible fact is that the heating element has failed and it might be too costly for a change.
2answers
Home touch ps-250B steamer
Need Water Tank top cap which is brocken
3answers
What are the advantages of using a steamer over an iron?
steamers are usually believed to be easier to use and less damaging to the fabric over time
Top Joy Mangano Garment Steamers & Presses Experts
ADMIN Andrew
ADMIN Andrew
john h
Stan Ford
Are you a Joy Mangano Garment Steamer and Press Expert? Answer questions, earn points and help others
