In the recent past while it was still working, I would sometimes hear a boom, and sometimes it would sound as if the gas was turned on full.
SOURCE: I have a kenmore gas range model #790. When I turn
dont use it may blow you up bad gas valve and saftey sender
SOURCE: Oven lights ,but doesn't heat to preset temperature
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Testimonial: "Exact problem and solution, Thanks"
SOURCE: I have a 79012-19 gas
You more than likely have a bad ignitor...and if you are getting a l;oud boom the you should also consider replacing the gas valve for the oven it should not be letting gas out until the ignition is hot.
Should be able to remove the bottom drawer and unplug the ignitor from below. Or you can cut the wires on the old ignitor and splice the new one in using ceramic
