Mongoose Exile 26 Men's Full-Suspension Mountain Bike Logo
Posted on May 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Adjust front suspension on a Mongoose XR-75
I bought a Mongoose XR-75 and the front suspension is way too soft. I was wondering if anyone knew if there is a way I can adjust it.
  • wvollejr May 13, 2009
    I was afraid of that. I know I have a cheap bike, but I'm working on making the best of what I got.
Anonymous
Level 2:
Scholar:
  • Expert 84 Answers
  • Posted on May 13, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
84
Questions
14
Helped
48046
Points
299
I dont think you can......because these bikes are made for confort at a cheap price..........
higher value bikes can be adjusted....they have special shocks and you can adjust on either soft or stiff ride.....
  • Anonymous May 14, 2009
    unless you wanna get the most of what you got....you can try improvising.....sometimes when i cannot get what i want i improvise and sometimes achieve what i want..........
    maybe there is a bike somewere with a similar model of frame but with tougher front shocks and you could get them on this one........
    good luck man...XD
2answers
How do i grease the bearings on an mongoose xr 75 mtb
I have the Mongoose XR-100, I pulled all bearings. I clean all bearing races and repack with grease or replace BB. Its my first step in flipping bikes also. Makes a world of difference in the ride. Cheap bike or not.
How do I figure out the value of my my Mongoose 26in. dual suspension, 21 speed?
Sorry about the request for more info about the bike I did not see the small print right above the How do I.
Anyway this link should help...I hope
26 Women Mongoose XR 75 Dual Suspension Bike
Personally, here in AUS bikes brought from Wallmart type department stores are very general purpose, meaning not professional, so the price doesn't hold in fact depreciates quite quickly so if you want to know for selling purposes than ask google, eBay, Amazon with words like used whether or not it has been, like unwanted gifts.
If I had to guess I'de say anywhere between $60 and $90 at best, but please feel free to do your own investigation and good luck.
3answers
Where can i get a left paddle for my Mongoose XR-75 Mnt. bike?
clean your garage and you will have it. or try bike shops.
May 26, 2014 • Cycling
Mongoose mozo m30 forks are sponggy
Change the spring to your load.
Adjust Mozo M30 Fork Suspension - Beckman Du-70 Forum
efratoium.xyz/Adjust-Mozo-m30-fork-suspension/
Results 1 - 15 of 15 - Mongoose XR 150 mozo m30 front forks rebuild. A quick ...Mongoose mozo m30 forks are sponggy on my XR150 mongoose mountain bike.
mozo??- Mtbr.com
forums.mtbr.com/shocks-suspension/mozo-167281.html
Feb 20, 2006 - 15 posts - ‎6 authors
... of a mozo m30? is it the junk im assuming came on my mongoose? ... into a halfway decent bike. and all i can get off the fork is mozo m30 ...
Mongoose XR250 Suspension Upgrades ' Bicycling Magazine Forums
forums.bicycling.com/topic/54635607127666779
Hi I have a problem, I've just recently bought a new mountain bike from eBay. It's a mongoose, can you tell me how to tighten the suspension, so it's for road use not cross country. I deflated the air...
Since you've let the air out of the shock you need to go to a Bike Shop for a refill anyway because a normal pump doesn't reach the pressures supplied by a shock pump. While you're there, have them set the bike up for your preferences and instruct you in shock operation.
2helpful
Loose handlebars on a Mongoose XR-75 mountain bike. I tried to tighten them but they still are loose. Help!
Check the splines on the handle bar. Just loosen the "clamp" and slide the bar over to one side enough so you can tell if the are stripped or not. If they are then replace the bar, if not then reassemble and try to put a littlle extra torque on the bolt.
I have noticed with the 2 of these bikes that I have that the bars do not like to stay tight for long, they tend to work thier way loose about every other time we use them. I just keep tightening them untill the splines strip, then pick up a new bar.
Contact Mongoose for parts info at: www.Mongoose.com under "about" click ask mongoose.
Good luck.
Adjust rear suspension on Mongoose XR-Comp Dual-Suspension
Here is a good source of info:http://www.bikewebsite.com/suspension.htm Let me know if this helps.
Jan 18, 2010 • Cycling
5helpful
Front suspension to soft on mongoose xr-75 mountain bike
The front forks aren't adjustable, as you probably figured out. You can, however, get harder springs if the springs can be accessed at the top of the fork tube. If not, do what I did on my mountain bike. I bought a better pair of adjustable forks that I found on eBay. It will take a bit of investigation on your part regarding the dimensions of the forks, so you get the correct length and width where the forks fit onto the frame (and the overall desired fork length), but you'll be a lot happier with adjustables.
Jun 14, 2009 • Cycling
Top Mongoose Cycling Experts
vince
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
