On/off switch 'disintegrated', what key combination can I use instead?
...is there a key-combination to turn the phone on (and off) as, 10 years into its very useful life, the on-off button at the top of the phone has now rather dramatically disintegrated. My phone is currently off -- although fully charge -- and sadly will stay that way forever unless I can 'keypad' it back to life! Thank you
I had a simliar problem with my k800i, it turned out that it needed its firmware/software updated. So u can either get it "flashed" at a shop (around £10) or you can try doing it at home but you'll need the software and the data cable for the phone. Google it i'm sure you'll find something. Good luck
You have to eject external memory card and after some time insert in your mobile and start. If this got again problem do it for 2-3 times . After that it will work.
NOTE: If your safe DOES NOT have a key, skip Step 3.
Turn the dial to zero.
Insert your key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; the door should open.
3 Digit Combination Locks for Security Safes 31-10-31
Insert the key; turn right.
Pull on the key while it's in the lock to open the door.
3 Digit Combination Locks for Gun Safes 31-10-31
Electronic Locks 31-10-31
Insert the tubular key into the lock to the left of the key pad.
Turn the key all the way to the right until the plunger pops out.
Press the five-digit factory code. The green Proceed light will come on.
4 Digit Combination Lock 31-10-31-10
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the fourth time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Are you sure that you are turning the dial correctly?3 Digit Combination Lock 31-10-31
Locksmiths agree If your safe doesn't have a key, skip Step 3. Turn the dial to zero. Insert your sentry safe key and turn it until the plunger pops out. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time). Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time). Turn the dial to the left to the last number (stop the first time on your last number). Pull the handle down; cracking the Fireproof Sentry Safe open.
The 1997 to 2003 Dodge Caravan and Grand Caravan use a standard key and
remote setup with a separate remote fob. However, the 2004 to 2009 Dodge
Caravan and Grand Caravan use a combination key and remote on one
device. To program a new keyless entry remote for the 1997 to 2003 Dodge
Caravan, you must have at least one functional remote, which is
required to enter synchronization mode. To program the combination key
for the 2004 to 2009 Dodge Caravan, you must have two functional
combination keys. If you do not, you'll need to see an authorized Dodge
dealer for keyless entry programming assistance.
2004 to 2009 Caravan Programming Instructions
Insert one of your working combination keys into the
ignition. Turn it to "On"; leave it in this position for about 10
seconds but no longer than 15 seconds. Turn it to "Off" and remove it.
Insert your second working combination key into the ignition
within 15 seconds of removing the previous key. Turn it to "On". After
10 seconds, you'll hear a chime and the "Theft" light will begin to
flash, entering synchronization mode. Turn the key to "Off" and remove
it.
Insert the combination key you want to program. Turn it to
"On." After 10 seconds, you'll hear a chime; then the "Theft" light will
turn off. When the light turns off, the combination key--including the
key and the remote--is programmed.
Repeat Step Three for each combination key you want to
program. A total of eight can be programmed.
