Nokia 210 ASHA DUAL SIM DUALBAND UNLOCKED GSM PHONE Logo
b
brijesh yadav Posted on Jan 07, 2018
I have nokia asha 210. I want gprs setting. my network provider is loop mobile. and i cant access my whats app application is predownloaded in my nokia asha 210. bt as and when i try to conncet whats app it show network connection prob try again later.? please help me for the same.
1 Related Answer
Anonymous
  • 80 Answers
  • Posted on Dec 18, 2010
SOURCE: I have nokia C-3. I
Connection name Loopgprs Data bearer: gprs / packet data Access point: www User Name: blank Prompt password No Password: blank Authetication: normal Homepage: http://www.loopmobile.in for more info go to http://www.loopmobile.in/vas/GPRS.htm
I want gprs setting for nokia 2626
Basic Setting Parameters for GPRS & MMS
Proxy Server :- 192.80.7.133, Port :- 8000
For accessing internet/WAP through your mobile handset :-
GPRS APN :- ntwap
GPRS Home Page :- http://wap.ntc.net.np (You can use your favorite site link also)more...
For accessing internet through computer by using GPRS service in your mobile phone :-
APN :- ntnet
Leave Username, Password and any other fields blank.more... For sending and receiving MMS :-
MMS APN :- ntmms
MMS Home Page/Server Address :- 192.80.11.180
Setting I for Nokia (2626,2600,2760, 3110, 3120,3600, Xpress Music 5200, 5220, 5300, 5610,5310, 6030, 6070, 6080,6085, 6151, 6233, 6280, 6300,6500 Slide,6600,6220,7210, 7360, ...)
1. Enter the main menu.
2. Select Settings, configuration, personal config. setting
3. Add new (From options)
4. Select Web and provide details
a. Account name: Ntc
b. Homepage: http://wap.ntc.net.np
c. Leave User name and Password field blank.
d. Preferred access point: No
5. Then define access point settings
a. Proxy: Enable
b. Proxy Address:192.80.7.133
c. Proxy port: 8000
d. Data bearer: Packet data.
6. Select Bearer settings.
a. Packet data access point: ntwap
b. Authentication type as Normal.
c. Leave other fields as it is.
7. Finally, activate the above created web
8. Restart your set and you are now ready to surf internet with NT Mobile GPRS service.
Note: In case if if third applications(like operamini,ebuddy,mig33) don't work, follow these steps:
1. Repeat the above steps upto 3
2. Select Access point and provide details
1. Account Name: Ntc
2. Go to Access point settings;
3. Data bearer: Packet data
4. Go to Bearer settings:
5. Packet data access point: ntnet
6. Network type: IPv4
7. Authentication type: Normal
8. Leave other fields as blank
3. Save the settings and activate it
4. Restart your set and you are now ready to surf internet.
2answers
I have for got my micro sd card password in nokia 210
Format the Micro SD Card in a Computer!
Then re try it in phone!
My nokia asha 301 is lock,needs to access control code.Please help me,My Emei is 357276054544650. Please help me
HI is your Nokia asha 301 mobile is locked to network provider then you can easily unlock it using network unlock code ..You can purchase code from online providers like SimpleUnlocking.com for reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone and use it with your sim then access all features like call ,text and so on ...
Unlock code virgin
Get the unlock code from the respective network provider as it is a safe way...You can follow the free instructions from Mobileunlockguide.com as an aid in the unlock process for your Nokia Asha 300.
Mobile Unlock Guide
I dont know whats my PUK code for nokia asha 300. HELP?
Call up your network provider for the puk code! PUK code is required when you fail to enter the correct security key asked after the phone is turned on. There is no need to worry on this, simple call up your network provider and they will give you the PUK code for your device.
1helpful
3answers
I need airtel GPRS configuration seting for my Nokia 2630 mobile.
Welcome to Fixya
General Packet Radio Service (GPRS) is a packet-based wireless service used for sending and receiving data through the internet protocol. With GPRS, the transmitted data is divided into various 'packets' before it is received by the user.
To use GPRS, users require:
  • A mobile phone that supports GPRS
  • A subscription or upgrade, as relevant, to the mobile network that supports GPRS
  • Some users would specifically require asking their mobile network provider to activate the GPRS while other network operators allow automatic access
  • Knowledge of how to do data transfers on their specific model of the mobile handset as it varies depending on the models and brands.
Setting up GPRS for your phones:
Usually activating GPRS on your phones are done by the service providers, and different service providers have different configurations. Additionally, the settings for GPRS vary based on the different phones and phone models. As activation is required before setting up you should know that activation process vary from one provider to other. It could be as simple as sending an SMS to a particular number or calling customer care of that particular service provider. Once the activation is taken care of, the setting of the GPRS is done based on the model of the phone.
It is important to note here that the setting for GPRS is different for different phones companies and may be different even for the different models produced by these companies.Therefore, it is recommended that you rely on the information given directly from the service provider. Again activation process may be different for postpaid and prepaid customers. So just call and demand GPRS settings for
Nokia 2630 mobile by the Airtel, They will send it free. Contact no of Airtel is 121
Anymore help, i am here to help
Thanks and Keep Visiting FixYa
2answers
I m using Nokia N6708 and using the sim of Tata Docomo.I cant access the internet.I am not able to understand the problem.Please can you tel me what internet settings should i apply in it.
Hi, the correct Web Settings are provided by particular Network carrier. Hence please contact the Customer Care of the Network Carrier to download the settings or enter the settings manually.
Please subscribe for GPRS internet service from your Mobile Operator after downloading the settings. Please contact the Customer Service Centre of the Mobile Network you are using to subscribe GPRS Internet.
4helpful
I have nokia C-3. I want gprs setting. my network provider is loop mobile. and i cant access my facebook application is predownloaded in my nokia c3. bt as and when i try to conncet facebook or chat...
2helpful
I want to activate my GPRS for my phone Nokia 2760. How? And i want to activate my mobile internet so i can explore internet through my phone. Thank you..
Before you can use GPRS technology, contact your network operator or service provider for availability of and subscription to the GPRS service. Save the GPRS settings for each of the applications used over GPRS. For 40 information on pricing, contact your network operator or service provider.
How to activate GPRS steps: Select Menu > Settings > Connectivity > Packet data > Packet data connection. Select Always online to set the phone to automatically register to a GPRS network when you switch the phone on. Select When needed, and the GPRS registration and connection are established when an application using GPRS needs it and closed when you end the application.
2answers
Unable to connect to the net with opera mini on my Nokia 3230
to connect to the internet & to send & receive mms messages you must activate the GPRS first from your network provider ...The best thing you can do is to contact the customer care of your network provider and ask for the activation of GPRS ...
they will tell you the procedure to activate it ....
they will tell the number to which the message to be sent to recieve the settings ....
so note that down and then follow the procedures told by them ...
you will receive the gprs settings(profile) also ... make sure of the charges with them there will be many plans & then get activated ...
after this you will able to connect to internet ....
if the customer people tell you that your handset is not compatible then you must tell to give the manual settings(includes ip address,APN,etc) so that you can only create the profile and input the information given by the customer care people...
any further doubts reply me
i am always here to assist you ..
thank you
bye...
Top Nokia Lands Phones Experts
Obehiaghe Adoghe
Obehiaghe Adoghe
Kolbrun...
Thomas Perkins
Thomas Perkins
Are you a Nokia Lands Phone Expert? Answer questions, earn points and help others
