I cleaned everything, replaced the fuse, replaced the spade clips and ceramic plates. I even put direct current to the fan and it worked. But after full assembly, fan no go. What did I miss?
Make sure that the pin on the back cover penetrates deeply enough into the unit to activate the power. I too couldn\'t figure out why mine wouldn\'t start until I pressed hard on the bottom right corner of the back cover. When I did the unit started immediately because the pin wasn\'t fully inserted. To solve the problem I held the cover tight with a piece of duct tape and haven\'t had a problem since.
SOURCE: Living Air XL (no smell)
pull out the plates and clean contacts that touch plates with rubber eraser then put plates back in check switch on back of screen to make sure its making contact.
~~~creekkid~~~
SOURCE: Alpine Air Living Air XL15 not producing Ozone or Deodorizing. New plates
Confirm that the appropriate sections of the circuitry are powered up and drawing power; check the interlock switch action; toss it back to the maker because the Hi-V transformer or ladder circuit or sense or hold caps were (if testing proves) never quite functional.
TEST THE CONTINUITY OF THE BULB AND THE WIRING AND THE PARTS INSIDE.
DOES THE UNIT STILL WORKS NORMALLY ASIDE FROM THE BULB?
