Korg Pa50 Professional Arranger Keyboard with SD Card Slot Logo
C
Claudio bauer Posted on Dec 13, 2013
Enciende pero no funciona kord pa 50 como desbloquearlo?
Problem with Korg PA-50 joystick in Program mode
Most likely the Program Mode does not copy joystick info.
Get the User Manual online, if you want Google
KORG PA50 FACTORY RESET
But then you will lose all your memories...
Dec 02, 2017 • Korg Music
2answers
En el pa korg 500 de error aparece os lectura de archivos Que Se Puede HACER
Carlos Hi
despues de formatear el equipo todo tiene que volver como recibistes el pa 500 nuevo de fabrica
2helpful
Kord pa 50 enciende, pero no funciona
ola claudio
tienes que resetear el organo y despues cargar el os
I have korg pa 50 fd my screen say korg pa 50 i get only one thing my paino work only
i have korg pa 50 fd when i turn on the power on screen says korg pa 50 only thing work just piano that is it my menu all freez to download the floppy disk is any body has any idea thanks
plz help me out
Aug 14, 2013 • Music
Qsc k12 schematic
Tengo el mismo problema, ella suena pero al subir la potencia se apaga, supongo es una soldarura mala, si es asi por favor especificame adonde y si es otra causa favor indicar.
Agradecido de ante mano!
1helpful
KORG PA 800
Many of these pedal have more than switches. Some use resistors as part of a matrix. The chances of success are only 50-50 unless you rewire the FC01 to be exactly the same as the EC5.
Korg pa-50 no sound from right speaker but has sound from left
Several things to check:
If the speakers are cut off when externaal cables are connected to line outs, possibly the jack sensing switch for the right channel thinks that a plug is in there... you might cycle one in and out to see if that might fix.
Another thing is they LIKELY have a PAN control setting and it might be set full left. The external MP3 would NOT be under PAN control, only the keyboard voices would be affected by it.
Feb 01, 2010 • Music
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
