There are no simple solutions regarding your problem, sorry.
there are factors that results in the 6680 not reading a memory card,
1) card reader IC is damaged 2) card reader assembly is damaged 3) UEM IC or CPU is damaged 4) program fault.
but you can verify that the phone is having problems by simply testing the MMC to other phones, if your MMC worked on other phones your phone has the problem and the above factors might be in play, i suggest your bring your phone for repair at shops or from where you bought the phone. those damaged parts are not user serviceable
your handset have a hardware problem.
the problem is with the bluetooth IC, this should be replaced.
bring your phone to a service/repair center that is authorized by NOKIA.
Bluetooth IC is not user serviceable, and replaced using special tools. And another thing, bluetooth IC is very sensitive, wrong procedure in IC replacemnet might lead your phone totally dead or not usable.
try check out for manual selection of network in your mobile if u get the proper signal then your work is done otherwise network ic might have been damaged u can get it done in nokia center or mobile repair shop
