Computers & Internet Logo
A
Anonymous Posted on Dec 13, 2013
Revo uninstaller pro 3.0.7 activation key
Are any activation keys for revo uninstaller pro 3.0.7
parvej nazir shaikh
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 01, 2014
parvej nazir shaikh
Contributor
Level 1:
Answers
Questions
0
Helped
147
Points
0
Revo_Uninstaller_Pro_3_0_7
No i downloaded revo uninstaller pro 3 but cant find a way to activate it
Call for expert assistance to activate Revo Uninstaller
+1(518)348-9393
tip
How to completely uninstall a software
How to remove leftover files,folders and registry keys after uninstalling a software:
OK, first lets see what actually happens when we install a software?
When we install a software it copies some of its files usually in C:\Program Files , C:\Windows\System32 , Registry.
If we uninstall a Software from Add/Remove Program ( Win+R --> appwiz.cpl), it removes some files from C:\program Files only.
It will not remove the softwares supporting files and folders from System32 or Registry.
Now lets see how to remove these leftover files:
I use a small freeware utility called Revounistaller for this process.
What is Revounistaller ?
Revo Uninstaller helps you to uninstall and remove unwanted programs installed on your computer even if you have problems uninstalling and cannot uninstall them from "Windows Add or Remove Programs" control panel applet. Revo Uninstaller is a much faster and more powerful alternative to "Windows Add or Remove Programs" applet! With its advanced and fast algorithm, Revo Uninstaller analyzes an application's data before uninstall and scans after you uninstall an application. After the program's regular uninstaller runs, you can remove additional unnecessary files, folders and registry keys that are usually left over on your computer. Even if you have a broken installation, Revo Uninstaller scans for an application's data on your hard disk drives and in the Windows registry and shows all found files, folders and registry keys so you can delete them.
With its unique "Hunter mode", Revo Uninstaller offers you some simple, easy to use, but effective and powerful approaches to manage (uninstall, stop, delete, disable from auto starting) and to get information about your installed and/or running programs.
You can download revo through : http://tinyurl.com/22scp8r
on Sep 14, 2010 • Computers & Internet
tip
Use REVO to totally Uninstall a Program folder and its Registry keys
Many program upgrades have their own old version uninstall prior to the upgrade install often times with a PC restart in the middle. For example Elecard MPG Player v4.6 to v5.6.
I have been looking for a way to do this for programs that don't adopt this technique for months now there are a few FREEWARE programs that are available like JV Powertools and Total Uninstaller but the Daddy of all has got to be REVO Uninstaller Pro.
Join them on RevoUninstaller@Facebook for a 20% discount on the FULL version its well worth the money I had major problems upgrading DivX Pro v7.0 to DivX Plus v8.0 it did OK on most of the install but left behind the old v7.1 DivX Convertor folder and registry keys and hid the serial codes on the new DivX Control Panel for all the older registered serials except the upgrade v8.0 serial.
Using this program I could locate the correct uninstall string even after the DivX own installer it leaves behind 198 registry items under the {7B63B....} key and 12 folders shown in red below using Total Commander with a total of 11.5 MB
Using REVO you can find where DivX is located in the registry and create a unique registration file just for my serials to un-hide them. Prior to the upgrade if you check DivX Pro v7.0 for updates it will tell you this as shown below it includes the H.264 Decoder v1.1.0
Sometimes after the upgrade you will not see the serial numbers like above or you may just see the DivX Plus Convertor 8.0 serial on the control panel it will just say registered if you want this to show you need to create a reg file replace the "" with your 20 digit serial that you purchased and all will now SHOW on the control panel the latest version of the pro codec is v6.9.2 you can check this using regedit and goto this reg key you will also see the other codecs that are loaded
You may see and extra line that has the same code as the procodec this is for the older professional version of the convertor before they rolled out the plus versionand can be removed from the DivX v8.0 Plus registry key
"converter67"=""
If you check for updates in the new control panel it does not tell you which versions that you have installed you will need to check the Product Registration page
This is what it will look like before you edit the registry key to show the serial numbers, NOTE these are stored unencrypted in your registry so make sure that no-one has access to them.
Cant activate revo uninstaller pro 3
Call for expert assistance +1(518)348-9393
2helpful
3answers
I can't uninstall Microsoft office 2013. When I click on uninstall in programs and features my machine starts gathering the files to uninstall and it fails to uninstall.
one option is to install a third party program like revo uninstaller to force uninstall the program.It can also be due to slow computer.Please let us know what operatiing system are you using
I am trying to either uninstall a whole lot of crappy games or if all else fails reformat the hard drive I am running vista
Revo uninstaller works great for things like that as it will remove registry keys that Windows won't. I've used it a lot and it works great. The price is right too. You don't need the pro version, scroll down and get the free version:
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Re-installing Vista, getting all the updates, and re-installing all your applications, etc. can be a real chore. Post back if you want to do that, but give Revo a try first.
2answers
I purchased Uninstaller,but can not register this software. Please inform me How to register.
First of all you must be sure that Revo Uninstaller isn't blocked by your firewall: Open the exceptions list and make sure it's in there. If it isn't then ad it yourself manually.
Next make sure you copy/paste the registration key exactly how they have sent it to you: no spaces or other symbols.
Now enter it in Help > Registration and press Activate Online button. This will close Revo Uninstaller Pro. Then you have to restart it manually. After a few seconds you will see on its title bar - Registered version. If this doesn't happen then the key is bad, you will have to contact them directly at
[email protected]
Activation key for revo uninstaller
Key for revo uninstallation pro 2.0.5
1helpful
Can't get Lavasoft Ad Aware to load. Just started doing that. I uninstall/re installed. Same result.
Download revo uninstaller from below link.
Click here
Download revo from above link and install it in computer then ope revo and select your software then remove all registry kets when revo ask for delete.
Your registry keys need to remove from computer revo can remove your software reg key.
Then install software then it will work fine.
Let me know if you need further assistance.
Thanks for using FixYa.
Grand Canyon Tech
Grand Canyon Tech
