Under Win7: Right-click the desktop, select Screen Resolution. Display should say Multiple Monitors, then under Multiple Displays select Duplicate These Displays or Extend These Displays. If you don't have Win7 please post your operating system so we can give directions specific to it.
try cleaning small lens on end of remote and receiver window on t-v (usually a small plastic covered window- on the front). if still have problem- could be you need new batteries in remote, or button on remote needs cleaning. a q-tip and some rubbing alcohol (91% or better!) use very little alcohol- just damp! may have some crud around button. good luck!
There should be a button on the remote called display and this should turn off the channel display. If it dosent then have the remote checked and make sure its working in that function. A universalo remote wont work as well in most cases. Good Luck
Your gonna need the original remote and press the display button. If the channel dosent go away theres a problem with the OSD(on screen display) IC, and is gonna need to be serviced by a pro. There are no serviceable parts inside these sets. Sorry I couldnt assist you more in this problem.
sounds like theres a problem with the front panel push button for the volume; In most cases it gets pushed too hard or just too week to stand up to multible presses and so the button cracks and de[resses the switch. If one switch is depressed none of the others will work as well . Simply open cabinet and pull back the chassis and relese the stuck button
