How to print labels from a bizhub 363
Self Help Product Support Konica Minolta Business Solutions Inc
try this
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: printing envelopes on the bizhub 252
After spending way too long messing around with this on my bizhub 250 here's what finally allowed me to print:
I simply changed the bypass tray setting from "envelope" to "normal". I kept the custom size the same (9 1/2 X 4 1/8) and it started to print.
Doesn't make sense, but you can give it try.
SOURCE: Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
SOURCE: how do I print labels on the bizhub 222
Be sure to load label sheets so that the side to be printed on faces down and a maximum of 50 label sheets can be loaded into the bypass tray.
USER MANUAL page 2-64
http://kmbs.konicaminolta.us/productsattachments/manuals/bizhub362SeriesCopyOperationUserManual.pdf
SOURCE: when i print label in bizhub c360 i put the label
Make sure the bypass tray is set to the correct size in the drivers.
