Citizen Eco-Drive Calibre 8700 Wrist Watch Logo
A
Anonymous Posted on Dec 12, 2013
Second hand not moving - Citizen Eco-Drive Calibre 8700 Wrist Watch
You shouldn't be running the chronograph timing all the time.
Jan 13, 2016 • Watches
The seconds hand on my invicta subaqua reserve does not move. It only moves when I start the chronograph. I've read the instructions time after time and can not get it to work.
The hand that moves when the chronograph is working is not a second hand. It will rest at the 12 o'clock position unless you are using the stopwatch. If your Invicta has a second hand, it is one of those small dials on the watch face.
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
My big second hand on my chrono watch does not move
Yes that's common, most chronograph watch's a small subdial is the times second hand. The large second hand is only for the timing function of the chronograph.
5helpful
Seconds hand not moving
The roles haven't been reversed. The seconds hand for normal timekeeping is the small one and the chronograph timer seconds hand is the large one. The reason for that is that it is much easier to determine the precise second with the larger hand. It working exactly as it should. If you like having the large second hand moving all the time you will not hurt the watch by leaving it running. All chronographs work this way. Nice watch - wear it well!
Second hand moves three seconds at a time
You have to replace capacitor in your watch. After that it will run like new.
3helpful
2answers
The second hand is not moving
make sure your mode is on time and not calender. if on calendar it sticks on the present month and does not move.
May 24, 2008 • Watches
Top Citizen Watches Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Citizen Watch Expert? Answer questions, earn points and help others
