Did either of you fix this fault? i have the same problem?
Did you happen to solve the problem? I am having the same exact issue with mine...washes fine, but won't do the spin cycle. it spins counter clockwise really slow at first, presumably to balance the clothes, and then starts to spin up clockwise (to do the spin cycle) but then whinnies and then stops....!
The wash cycle completes, but leaves the clothes sodden. I consulted the troubleshooting guide and it looks as if the "electronic unbalance detection device has cut in because the laundry is not evenly distributed in the drum".
I have tried running a spin cycle with nothing in the drum and it still doesn't get up to speed (it attempts to, but just seems to trip out). The machine is draining with no problems.
Does it look as if I need new brushes/motor? A friend has had a look at the brushes, he does think they could do with replacing.
Any suggestions would be much appreciated.
Many thanks,
Adrian
P.S. The machine is approximately 4 years old.
won't spin more than 5 secs.
I have the same problem. Did you ever figure out what was wrong with it?
