7 blinking lights, disconnect the SC board changes to 6 blinking lights
7 blinks? Driver SOS 2 SU / SD / SS Boards (SC floating voltage area). These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
SOURCE: Panasonic th-50pz85u: TV will not
10 blinks error code is definitely due to a malfunctioning A-board. Since you have already replaced it, the only possibilities are
1)Either you have obtained a malfunctioning replacement OR
2)You did not get the correct revision version. Not that the same model number of the tv can use different sets of parts. That is why it is always recommended to order by part number. I have had a customer recently who had a similar problem and it turned out to be incorrect version of the replacement board. So check the part number of the replacement and the original . Also compare the revision versions of both and see if everything matches. Please let me know what you found.
SOURCE: seven blinking light
7 blinks Driver SOS 2 SU / SD / SS Boards Visit the site named 'Electro-help' for more
details. Click this link. View it in
'Flip card' option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window. It will make search easy. Some times, the ads attached with each
posts, both at the right and bottom, might help you to find the availability of
spare parts. There are more than 850
posts to different brand TVs now.
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
