www.fixya.com > Forum > Tags > check engine light blink 5 times rsx
Question about 2012 Big Red MUV ... Check engine light blinking on Honda big red muv Check engine light slowly blinks ... My 2014 honda foreman 500 es 4x4 neutrallight blinks 4 long times and 2 short times and will not shift into gear.
Honda blink 3 times ATVs Questions & Answers - Fixya
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
4 Blink 9 out of 10 times is your lamp fan. Check and make sure it clean and free of debrey. Spin it and see if there is any grinding noise. If after you clean and reassemble and the set still shuts down, either replace the lamp fan or check your outher 3 fans as well.
Hi there, 5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing. Hope this helps TV_Doctors
Hi, 4 times red standby light indicates problem with exhaust fan that is not running for some reason. Recheck fan that you replaced and make sure its connector is plugged properly and it running freely. 4 times red light blinking is fan error in this tv. Thanks.
Red light blinking 4 times on Sony bravia TV.This is the problem of INVERTER BOARD.The inverter board has to be replaced.Every Sony bravia tv has a particular model number and the Inverter board part number depends on model number of the tv.
As you have not mentioned the model number so the exact part number of the inverter board is hard to tell.But you can get the required inverter board part for your tv from
www.partstore.com
Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV. Please check fan connectors and make sure all are plugged securely.
you can shove your premium assistance program , i spent 2000.00 already
tv shuts off for no reason...red light blinks 4 times ...stops...blinks 4 times....stops....etc....what can i do before taking it back??
this is a brand new unit....fantastic picture....fix my problem
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
