Question edited for clarity, and spelling 'brain' to Braun, and 'thermoter' to thermometer, 'comes in' to comes on..
Question moved from Cars and Trucks Category.
Duplicate question deleted. Refresh page to see your question published.
There are some ideas here, but it sounds faulty and needs warranty return or repair.
If your Braun Thermoscan 6022 thermometer is not switching on even after you have replaced the batteries, there could be a few possible causes:
Battery installation: Make sure that you have inserted the batteries correctly, with the correct polarity. Check the battery contacts for any corrosion or debris and clean them if necessary.
Battery type: The Braun Thermoscan 6022 requires two AA alkaline batteries. If you have used a different type of battery, such as rechargeable batteries, this could be the reason why the thermometer is not turning on.
Battery life: Even if the batteries are new, they could be defective or may have run out of charge quickly. Try replacing the batteries with a fresh set of AA alkaline batteries.
Reset: Try resetting the thermometer by removing the batteries for at least one minute and then reinserting them. This can sometimes help to reset the internal electronics of the thermometer.
Faulty thermometer: If none of the above steps work, it is possible that the thermometer itself is faulty. In this case, you may need to contact Braun customer support for further assistance or consider purchasing a new thermometer.
You have to hold the blue/green button in whilst taking temperature. I forgot this and was just pressing it and getting this message. Operator error :)
So a very simple fix is to just clean the corrosion from the battery terminals inside the thermometer. You'll need a Torx T9 screwdriver (Maplin, eBay, Amazon, maybe pound shops).
