How do I get my power outlet on my stove top to work? is it a fuse problem?
SOURCE: replacing electrical outlet for stove top burner cartridge
You need to remove the cartridge then all of the screws that are around the inside perimiter of the well. You may also need to remove the control panel via the screws securing the top trim and the bottom flange. The part numbers for the wires with contacts are as foloow: 71002326 blue wire, 71002604 brown wire, 74005845 violet wire and w10116778 yellow wire. They should retail at @ 7.-8$ each.
SOURCE: kenmore eletric range 790-96213404. stove
Hi Please check this diagram....if you have already replaced both
the boards and the door is closing properly so the issue is with the oven temp
sensor that is bad or a broken loose wire that is causing this issue. Hope this
helps...please post back for further assistance. Daniel
