Computers & Internet Logo
Robert Bowen Posted on Dec 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error while initiailizing the NIC
Wont boot up
max carson
Level 3:
  • Master 7,627 Answers
  • Posted on Dec 13, 2013
max carson
Master
Level 3:
Answers
7627
Questions
Helped
1014928
Points
21773
A bit vague? Have you tried a System Restore, to a date before this issue OR a System Recovery? You didn't supply much info? Make, Model of Laptop or the OS you are using?
NON SYSTEM DISC ERROR HP 6545B
cmos RTC coln cell is dead
PXE is must be enabled in bios, when the coin cell goes
dead PXE flips on and the PC tries to boot from PXE remote servers. (business class) that you do not have.
1: new coin cell replaced. bat.
2: in bios (esc key) click reset bios defaults.
3: set time and date in bios.
4: set PXE off in NIC page BIOS (nic)
5: set PEX off in boot order. if seen.
6: set hdd0 back to top of list in boot order page , bios
7: save (bios) key
8: exit bios
9 : cold boot PC bingo HDD 0 boots again./
Comp frozen.will not connect to windows 7..error while initializing the NIC
PXE ROM boot is a network boot that kicks in when all else fails. If you have or can borrow a Win7 boot disk, watch the screen closely when powering on the computer and it will tell you which key or keys to press to force a boot from the the cd/dvd rom. If you can boot from the optical drive , it may give you the option to repair Windows. READ THE SCREENS CAREFULLY AND CHOOSE WISELY - if you do not you can overwrite windows and ALL of your personal data. IF you have a hard disk failure, windows should tell you so...
Ok 1. acer; aspireone 2.Wont boot up 3. PXE-E63:Error while initializing the NIC 4. PXE-MOF Exiting Intel PXE ROM 5. No bootable device--Insert boot disk and press any key. Thic pc has vista on i
switch to boot devices (F2....F8,)do this as soon as you press power button.keep pressing to bring up bios disable all bootable items in list except cd rom.give this a try good look
Error pxe-m0f Fujitsu Lifebook S6520 Notebook
Re boot, Go into bios and turn off network boot, or anything related to boot to NIC, because there are different kinds of bios, turn off network boot.
I have an Optiplex GX 620 Mini Tower that displays a NIC failure error at boot. The error message reads "NIC failure. Press F1 to reboot or F2 to go in to setup." The PC did not boots
it means your hard disk is not detected by system, check all connections of hard disk, if problem remains check with another working hard disk
1helpful
Pxe e63 error while initializing nic no bootable
here we go >
power on your netbook press delete to go to bios setting goto boot or boot device priority then set it to harddisk(your current setting is pxe or network boot) then press f10 to save enjoy
thanks for using Fixya
2answers
My computer keeps trying to boot from another source
You would have to go into your BIOS by hitting the F2 key as it is turning on. Then go in, and under Advance settings, make sure that the only place that it boots from is the Hard Drive. Make that the primary.
If it still has an error coming up, then it might be a file system issue with the OS.
XP won't boot without IBM 10/100 EtherJet NIC
Check the BIOS to make sure the machine is not trying to boot off of the network card (PXE boot) and make the hdd in question the primary boot device.
IBM Netvista PCI/PNP Slot 3 Error
I had to remove the old network card and replace it with a new one to resolve the issue.
3answers
NIC error/keyboard fuse failed
hear what u can do u can try resetting the bios or taking out the cmos battery for like 30 to 45 mins and the error u r getting will go away but if the NIC error keep accuring well there a problem with yr network card and for the hard drive when the pc is now booting up all dell normally comes with a testing device tool to get this testing device u can press F2 on when yr pc now going throught the post and just select hard drive testing...if it fines an error with the hard drive well u need to replace it....ok let me now if that work.
Grand Canyon Tech
Grand Canyon Tech
