There are only 2 wires coming out of the wall. One wire was connected to the W terminal and the other to the RH terminal on an old ritetemp model 8022 thermostat. What 2 terminals do I now need to connect to make the Honeywell unit work?
See RC and RH, RC is for cool, RH is for heat, you wire the red wire to the RH or red terminal ,either one will work actually but we generally switch the hot leg of power, W is the heat circuit
Hello Don,
I assume your trying to hook up some kind of heater? If so you would want to hook up the wire that was or is on the RH terminal (old t-stat) to the new R or Rc terminal on the new t-stat. Next take the wire that was on the W terminal ( old t-stat) and connect it to the W terminal on the new honeywell t-stat. If this is a digital thermostat then batteries will be required for its operation.
SOURCE: Thermostat Wiring: W2? E? Where to connect?
You have a heat pump. You need a thermostat for "Heat pump with Electric back-up heat". Make sure the 'stat has either an "aux" (auxilliary heat) or an "E"(Emergency heat) terminal. The wiring instructions will be provided with the thermostat.
SOURCE: Honeywell RTH 230B Thermostat Wiring
put the jumper back in RC and RH and that should do it.
SOURCE: Wiring new RTH2310 DIY Honeywell
is the j2 jumper on the backside of the display set for hg instead of he - g is gas/oil e is electric - if correct take thermostat wires off screws and turn power back on - see if burner fires up with no thermostat wires connected - old wires could be touching somewhere when put on new thermostat
