Question about Korg Pa800 Synthesizer
Is there a master reset
My n5 keyboard is a whole tone down. how do i cure this and also is there a master reset
    President:
  • 1,140 Answers
Look at http://www.korgsupport.co.uk/sitemap.cfm under Tutorials/ resetting and initialiising your product.I don't have a Korg but it sounds like you have set the transposition for the whole keyboard down a tone. Hope this helps.
Posted on May 13, 2009
SOURCE:
Casio WK-3500 How to save keyboards/tones
Yes there's a way. Use Registration Memory (I shorten it to: RM) ..
RM have 8 banks and 4 bank numbers. For changing banks, press BANK several times.
Example :
  • choose tone (eg:500)
  • press BANK where you want to store. (eg:1)
  • while holding down STORE button,press registration number where you want to store (eg:3) Release store button. Finish.
Next :
  • choose tone (eg:038)
  • while holding down STORE button,press registration number where you want to store (eg:4) Release store button. Finish.
Anytime you press RM bank 1 number 3 (one key), the sound is 500
Anytime you press RM bank 1 number 4 (one key), the sound is 038.
Notes:
  • RM not only can save tone, but can store style,overall setting live performance,etc.
  • RM functions are disabled while you are using the SMF player, song memory or demo.
  • RM are also disabled while you are using the floppy disk drive.
Jul 10, 2015 | Music
How do I recover the accompaniment?
When you press the accomp button does it show up in screen?
If not you have a button/switch issue.
Try a master reset - hold down top / highest note whilst turning on.
This will factory reset and may clear the issue.
Aug 01, 2014 | Yamaha PSRE413 Keyboard
Sound stuttering
Hi, This and a lot of similar keyboards have gold flashed pads on the PCB and the keys press one or two rubber caps, with conductive pads in them, down.
Clean the pads with isopropanol, (and nothing else) and it will be cured 99% of the time. If a few notes do not work, especially after heavy use, then the rubber caps can be replaced.
Taking the keyboard apart is long winded because of the number of screws involved.
The job its self is simple enough, but take note of the order things go in and where the screws go.
Hope this helps, Chris.
Jan 09, 2014 | Casio Music
How can I do an internal factory reset for my Privia PX-130?
Turn the Keyboard off the press and while holding down the [TONE] AND [FUNCTION] buttons power on the keyboard. Wait until all reset is done.
Aug 22, 2013 | Casio Privia Px330 Px-330 88 Key Digital...
Hello, I have a big problem with my korg pa800 , yesterday I was on gig, and suddenly the whole keyboard in the middle of playing got the distortion on every sampled or fabric tone!!! I have tried...
It will require repair. I suspect by you description that the D-A convertor has failed. This is a chip that is far beyond a DIY project to change. Do further testing to make sure the power supply voltages are correct and that headphone output sounds the same problem.
Here is your service manual: http://elektrotanya.com/korg_pa800_sm.pdf/download.html
Scroll down to "get manual" and click to download the manual. IGNORE other download links.
Aug 07, 2011 | Korg Pa800 Synthesizer
I could not able to select the tones.It needs to be reset to the factory level.Please help me to reset the Keyboard to the original status.?
Sometimes companies use the same sequence for all their synths...
Here is one to try:
How do you reset casio keyboard lk-60?
This is how. 'Turn keyboard of for 5 seconds then turn it bak on and play"e-flat,g-flat,e-flat,b-flat,g-flat,e-flat,g-flat" then turn keyboard of and unplug and wait 5 minutes then plug back in in,...
Note: It is NOT clear if you need to hold the notes down as you play them or press and release.
Here is another for Casio:
From the FILE menu, select INITIALIZE to select the sub menu. Select the SYSTEM option to return the keyboard to its factory settings. Keep in mind that this operation will delete anything that is stored in the keyboard memory. When you see the InitSys? on the screen, select YES. I hope this helps......
I could not find anything specific to the 810.
If these don't work, then the way to reload is via the MIDI port which will accept Sysex commands and data. You can probably find a data dump online for this at the Casio site..
You will of course need to have a MIDI port on your PC.
Sep 16, 2010 | Casio CTK810 61 Key Keyboard
How to do a master reset a casio ctk 496
According to the manual for the 496, "All keyboard settings are returned to their initial defaults whenever keyboard power is turned back on after being turned off by operation of the Power/Mode switch or Auto Power Off.
Nov 26, 2008 | Casio Ctk 496 Electronic Keyboard with 61...
Korg Pa800 Synthesizer Logo
3,424 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Experi
Level 1 Expert
David Gust
Are you a Korg Music Expert? Answer questions, earn points and help others
