Question about Kal Equipment Battery Tester - KAL Equipment
Kal equip 4260 melted after a routine test. after performing a routine test, the technician hung the tester up with clamps attached to the side. After a couple of minutes the tester began to smoke and melt the internal parts.
  • badenhop
    badenhop May 11, 2010
    It melted with no attached load? It melted through a steel housing?
2 Suggested Answers
SOURCE:
gotgeek2
  • 565 Answers
SOURCE: i need an instruction manual for a kal model 4260
I'll tell ya, it sure took some digging to find that one. Evidently KAL Equipment was acquired by Actron.
http://www.actron.com/media/usermanuals/KAL4260_0002-000-2374%20PW_Battery%20Load%20Tester_MNL_Eng.pdf
Posted on Feb 24, 2009
Need the model number of a fluke clamp on meter, serial number is 21530517
try looking for Invoice (it should have model) on it or ask place where you purchased unit from
Mar 25, 2014 | Fluke 321 Clamp-On Meter Electrical...
Plugged in a tester and the folowing code came out p0135 02 sensor heater circuit bank please advise on location and rectification
first off ECU can never tell you what is bad, it can only tell you what tests failed.
135 test. failed.
Front sensor, left side of engine (engine not stated in post)
verbetum suz
P0135Heated OxygenSensor(HO2S)Heater Performance
a kinda dumb way to stated this Performance.
a better word would be HEATER dead,
or the heater no longer draws current is the better words.
this has 2 causes.
1: heater is dead, buy a new sensor they last 100k miles.
2: the wires to it fell off, stopping current flow, dead.
the latter issues, is a look and see it. it melted or broken wires.
http://www.fixkick.com/CEL/DTCs-1.pdf
you can read this page A80 in the FSM.
see this.?
http://www.acksfaq.com/96-FSM-v2-6E3-A-part2-pdf.htm
more that 4amps draw is a shorted O2sensor
less that .22amps is open sensor.
why? , well they all go open well before 11 years running.
or last worker, failed to put back the clamps to wires. allowing them to hit the exhaust and melt and short or open.
and this being bad wastes lots of fuel , so there is a return
on investment here.
Oct 17, 2013 | 2002 Suzuki Vitara
Alternator
Instructions1 Clean the positive and negative battery terminals to ensure a good connection with the tester's clamps.
2 Connect the positive and negative clamps to the appropriate battery terminals. The clamps must make firm contact with the battery terminals or the test results will be inaccurate or the tester may not work at all.
3 Turn the tester on and choose the option for "full charging system test." This will test your battery, starter and alternator and provide the most accurate picture of the problem.
4 Follow the directions on the tester's screen. These instructions will include cranking the vehicle after the battery test is performed, holding the engine at a certain RPM range and turning on certain accessories.
5 Read the results displayed on the tester's screen. The tester should scroll through the results, starting with the battery, then the starter and finally the alternator. An alternator test result showing diode ripple problems indicates a bad alternator.
Thanks
Apr 02, 2012 | 2001 Chevrolet Impala
Electrnic hand growler to test electrical armature with green and red indicator
Go on E-bay for electrical test equipment and look for growler.or go google and type in armature growler test equipment and see what you get.
Sep 05, 2011 | Hand Tools
1999 ford mustang cobra alternator troubleshooting
Generally, you can check and test alternator with this procedure...
1. Clean the positive and negative battery terminals to ensure a good connection with the tester's clamps.
2. Connect the positive and negative clamps to the appropriate battery terminals. The clamps must make firm contact with the battery terminals or the test results will be inaccurate or the tester may not work at all.
3. Turn the tester on and choose the option for "full charging system test." This will test your battery, starter and alternator and provide the most accurate picture of the problem.
4. Follow the directions on the tester's screen. These instructions will include cranking the vehicle after the battery test is performed, holding the engine at a certain RPM range and turning on certain accessories.
5. Read the results displayed on the tester's screen. The tester should scroll through the results, starting with the battery, then the starter and finally the alternator. An alternator test result showing diode ripple problems indicates a bad alternator.
Hope helps (remember rated this).
  • Step 2 Connect the positive and negative clamps to the appropriate battery terminals. The clamps must make firm contact with the battery terminals or the test results will be inaccurate or the tester may not work at all.
  • Step 3 Turn the tester on and choose the option for "full charging system test." This will test your battery, starter and alternator and provide the most accurate picture of the problem.
  • Step 4 Follow the directions on the tester's screen. These instructions will include cranking the vehicle after the battery test is performed, holding the engine at a certain RPM range and turning on certain accessories.
  • Step 5 Read the results displayed on the tester's screen. The tester should scroll through the results, starting with the battery, then the starter and finally the alternator. An alternator test result showing diode ripple problems indicates a bad alternator.
  • Read more: How to Test a Car's Alternator | eHow.com http://www.ehow.com/how_2079784_test-cars-alternator.html#ixzz0spTYveGJ
    Jul 05, 2010 | 1999 Ford Mustang Cobra
    I need an instruction manual for a kal model 4260 battery tester.
    Feb 20, 2009 | Kal Equipment Battery Tester - KAL...
    Kal Equipment Battery Tester - KAL Equipment Logo
    287 people viewed this question
    Top Kal Equipment Measuring Tools & Sensors Experts
    Vuk B
    Tom Chichester
    Are you a Kal Equipment Measuring Tool and Sensor Expert? Answer questions, earn points and help others
