Valve settings
- Pull the hand brake and put transmission in neutral.
- Remove spark plug cords.
- Remove the spark plugs.
- Remove the Tappet cover
- Lift up the left front wheel.
Cylinder number 1 is toward the pulleys and belts side.
- Rotate the crankshaft anticlockwise with socket and extension rod and bring the valve tappets (intake and exhaust) No. 4 cylinder on dancing position.
NOTE: THERE ARE OTHER WAYS ALSO TO ADJUST THE FOUR VALVES AT A TIME. BUT AS DIY FOLLOW THE FOLLOWING METHOD TO AVOID ANY CONFUSION.
- Adjust the valve clearance of number 1 cylinder.
Valve clearance:
Intake 0.18 - 0.22 (cold) Exhaust 0.25 - 0.28 (cold)
- Rotate the crankshaft anticlockwise to bring the valves of cylinder 2 on dancing position and adjust the valves of No. 3 cylinder.
- Similarly rotate the crankshaft to bring the valves of No. 1 cylinder on dancing position and adjust the valves of No. 4.
- Rotate the crankshaft anticlockwise to bring the valves of cylinder No. 3 on dancing position and adjust the valve clearance of No. 2 cylinder.
