Display show scrolling Precor banner, stop succeeds in pausing banner, display will not result in anything else
SOURCE: Precor 9.25i Treamill scrolls message "button is pressed"
Press Enter,speed up and speed down simultaneously. Then enter to view error buffer . press quick start/pacer-stop simultaneously to reset error buffer log. Hope this helps
SOURCE: My precor c954i displays message STOP KEY and will not run? How come?
1) adjust the reed swithc, clean , and tigh the wire connectors very well
2) run the software calibration for diagnostic and troubleshooting.
God bless you
SOURCE: precor efx 5.17 which intermittantly stops counting strides and freezes the display
please follow this steps: Remove the bolts or screws
securing the console to the upright assembly. Lift the console and
confirm that the cable connections are secure. Remove the cover from the
console's battery bay and install a fresh set of batteries. Replace the
battery cover. Detach the ends of the pedals
from the crank axles. Remove the left and right disc shields and side
shields. Inspect the interior of the base unit and locate the flywheel. Inspect the flywheel as it
turns. Locate the magnet installed on the flywheel. Turn the flywheel
until the magnet passes in front of the nearby reed switch. Loosen the
screw securing the switch in place. Rotate the switch to reduce the gap
between it and the magnet. Tighten the screw.
Step 1
Step 2
Step 3
God bless you
