So on my tv, especially in the edges, there is a red shadow behind everything. It does not do this in the middle of the screen. I have tried doing the manual convergence to the best that I could get it but that does not help. What would I need to replace in my tv to fix this problem.
SOURCE: Convergence board replace, still cannot manually adjust covergence
Do you have everything pluged in?
did you get a new board or repaired board. I think it's defective if everything checks out
SOURCE: Samsung HCL5515W red convergence problem
sounds like your convergence IC's have fail and possibly a bad dcm. Some of there models have a small board with the ic's them. It may be cheaper to replace the board. But you can repair it if you have proper equipment
SOURCE: Convergence Problem
sounds more like the convergence amp ICs STK392-040 you can get replacements here that comes with instalation instructions.
http://servicemanuals.vstore.ca/
SOURCE: Convergence adjustments
Replace both convergence ICs nuber STK392-040 that should take care of the problem. you can get new replacement ICs at the following link and they will send free instalation instructions with pictures so you can install the new ICs. heres the link.
SOURCE: Blue Convergence
Hello All Above,
Your one and only problem is a bad convergence Amp
board. Changing it will fix your set. You can contact
http://www.interactiverepair.com for step by step assistant with
installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
