Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KV-32FS100- blinks 6 times, but sometime will come on
Sony KV-32FS100
2 weeks ago standby light started flashing. Flashes 6 times consecutively. Would not turn on. If I press the power on button twice on the remote it comes on. Also notice when I unplug T.V and then replug it makes the sound like the T.V is trying to come on. Any idea how to fix?
    Top Expert:
  • Sony Master
  • 54,195 Answers
Probably the power supply is failing
Posted on Jan 06, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
try checking the soldered joints on the main circut board that attach the larger metal components...I re-soldered aprox 40 connections and now the tv works great!
Posted on Jan 31, 2008
Anonymous
SOURCE: Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Posted on May 09, 2008
jerryg50
Jerry Greenberg
  • 1691 Answers
The relay is in the power supply area. I am sure that the fault is not the relay.
It is very common that there are various components starting to go off spec from age. Most of the failures are in the scan amplifiers and power supply areas.
It is also possible that the CRT emission is too low from age. What happens is that it is on the minimum edge and this explains why the set may turn on some of the time.
When the main uPC in the set sees any potential fault conditions it will go in to a protection mode to prevent damage and to be safe. Your set is probably borderline to operate.
Considering the age of your set, I would be shopping for a new TV set.
Jerry G.
Posted on Jul 12, 2008
Anonymous
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
Anonymous
  • 63 Answers
SOURCE: SONY KV-32FS100 TV DOSENT COME ON ONLY FLASHING
This is the error code for what is termed IK which controls the video to the pic. tube essentially. The most common failure I've seen is the video output i.c. on the crt board also known as the C Board. This is IC702 and is available, the generic number is on the i.c. and can be purchased at a place like mcmelectronics.com . Also someone may have turned up the screen level control located on the flyback transformer. If this is too high the set detects the excess beam current and shuts the set down. If you are not into tackling a problem like this yourself you will need a tech to check it out and give you an estimate. The repair cost would be mostly labor for the diagnosis and part replacement. I don't believe you would be looking at much for parts themselves.
Posted on Nov 25, 2009
Testimonial: "a perfect solution i will replace the part ,,i know how to repair the tv,, i have the equipment,,to do it i just diddnt know the code"
Little red light on front flashes and no picture. Help! Thanks...
The standby light should be blinking in a repeated pattern. Pleawe count the blinks and report that number here. That count indicates the circuit that is having a problem. Also, please confirm that the set is model number KV-32FS100.
Thanks,
Dan
Nov 19, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony trineton KV-34HS510
let me know how many times standby light flashes. this info will help me to assist you to resolve tv problem.
Sep 05, 2008 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony Wega Triniton KV-32FS100 TV For the last week my TV has been going to a black screen for 10 secondsor so then the picture returns. It has been continual. Last night itstopped going to black screen,...
Jun 01, 2017 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron Wega model KV-34BR800
For the last week my TV has been going to a black screen for 10 seconds or so then the picture returns. It has been continual. Last night it stopped going to black screen, but now the standby light flashes 5 consecutive times and the color went haywire. A lot of red and everything that is suppose to be black is green.
I did a soft and hard reset with no success. What's wrong and is it worth fixing? Bought new in November 2002.
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony fd trinitron wega Kv40
The 6 blinks indicate a loss of horizontal and could ba a bad capacitor or bad jungle IC. I'll look up the part numbers anbd designations for you.
Dan
Jun 25, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Dec 22, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
125 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
