Televison & Video Logo
H
Howard Beey Posted on Dec 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Television remote codes - Hisense TC24FS2H TV
Level 3:
Top Expert:
  • Hisense Master 76,851 Answers
  • Posted on Dec 12, 2013
Hisense Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994670
Points
237762
0183,0119,0185,0114. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
How do I link my new remote control to my television without the manual ?
  1. Identify the brand and model of your television: Look for the brand name and model number of your television. This information is usually located on the back or side of the TV itself. Knowing the brand and model will help you find the correct remote control codes for programming.
  2. Search for remote control codes: Most remote controls come with a set of codes for various television brands. Without the manual, you can try searching for the remote control codes online. Many websites and databases provide lists of codes for different TV brands.
  3. Entering the codes manually: Once you find the code for your TV brand, follow these steps to enter it into the remote control:a. Turn on your television. b. Press and hold the "Setup" or "Code Search" button on the remote until the indicator light turns on. c. Enter the code for your TV brand using the remote's number buttons. The indicator light should turn off if the code is entered correctly.
  4. Test the remote: After entering the code, try using the remote to control your television. Test functions like power on/off, volume, and channel buttons to see if they work correctly. If they do, the remote control is successfully linked to your television.
If you don't have success with the first code you find, try other codes for your TV brand. Sometimes, multiple codes are available, and you may need to try several before finding the correct one.
If the above steps don't work, it's possible that your remote control uses a different method for programming. In that case, try searching for the specific programming instructions for your remote control model online. Manufacturers often have manuals and programming guides available on their websites.
If all else fails, consider contacting the manufacturer of the remote control for assistance or purchasing a universal remote that can automatically search for the correct code for your television.
I need to link my new remote to my television & have lost my instruction manual
If you have a new remote control for your television and you don't have the manual, don't worry. You can still try to link or program the remote to your television by following these general steps:
1helpful
Sansui LCD TVcode for sansui LCD TV
The codes for a universal remote to work with a Sansui television are:
Sansui television remote code 834
Sansui television remote code 0310
Sansui television remote code 0394
Sansui television remote code 20695
Hi. I need the code for my sensui TV please. I have a remote. But forgot the code. Thanks
These codes are compatible with Universal remotes and Sansui televisions that have a functioning infrared device.
I have a Samsung TV iamuseing a ermsom remote need codes for this remote
Search Results
    Remote Control Codes
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    ... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...‎Guide to Programming the ... - ‎Download the Manual - ‎8 Device Learning Jumbo ...
    Remotes - Device Codes - HiFi Remote
    www.hifi-remote.com/codes-tv.shtml
    TYPE, BRAND, CODES ... TV, Emerson, 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, ... TV, Samsung, 0019, 0060, 0030, 0056, 0178, 0032.
Can't find the codes for my emerson tv codes for
Instructions
    • 1Remove the battery cover and insert new batteries into the remote. Press the "Power" button on the television to turn it on.
    • 2 Press the "PRM" button that is in the lower left corner of the remote control. You should see the signal indicator light come on.
    • 3 Click the DTA800 TV Codes link in the resource section to view a list of program codes for the converter box. Enter the 3-digit code for your television by pressing the number keys on the keypad. Press the "OK" button when finished. You should see the indicator light turn off.
    • 4 Point the remote at the television and press the volume keys on the remote control. If the volume for the television changes, the remote has been programmed successfully.
    • 5 Enter another 3-digit code for your television if the first code fails to program the remote
    • CODES : Emerson
      • The RCA Universal Remote has 17 different codes for Emerson televisions. These codes are 011, 026, 027, 028, 029, 030, 031, 032, 037, 042, 053, 064 065, 067, 075, 076 and 079. There are 18 different Emerson VCR codes. These codes are 008, 009, 010, 013, 015, 020, 023, 027, 034, 041, 042, 047, 057, 062, 065, 067, 068 and 070. There are no codes for Emerson cable boxes.
      Hope this helps. =)
1helpful
3answers
Samsung AK59-00123A remote to a M261VP vizio tv
Hello
[1] Switch your television on
[2] Point the remote control towards the
television
[3] Press and hold the TV POWER button, and
then enter the two-figure code in the table
to the right that corresponds to the brand of
your television by pressing the appropriate
number buttons.
If your television is compatible with the remote
control, it will switch off.
The remote is now programmed to operate
the TV.
The code for Zenith TV is [TV POWER + 63]
2helpful
I need a remote code for a rca remote for the olevia remote control can you help
Unfortunately Olevia is one of those t.v. brands that is not compatible with many universal remote controls. They make a Universal Learning Remote specifically available from Olevia on their web site that may solve your problem if your universal remote control turns out not to be compatible with your Olevia television.
As for what codes you can try, there are many, and the codes depend on your universal remote control brand. Many times, an RCA code will work for Olevia televisions, so you should try the RCA codes that come with your universal remote first, before trying any of these other codes.
If you have a Dish Network Universal Remote you can use code 506 or 127.
Direct TV remote codes vary by model number on the remote control, but the following codes work with most Direct TV remotes: 506, 127, 11144, 11240, 11331, 11610
Cable Vision use code 506
Charter and Movie Box remotes you can use 1144 or 1178
Comcast codes are 11144, 11240, 11331, 21075, 10159, 10154, and 10088
Cox code is 1610
Brighthouse remote codes are 1610, 1144, 1240, and 1331
Time Warner remote codes are 1610, 1144, 1240, 1331, 432, and 1610
If none of these brands are what you are looking for as far as your Universal Remote Control is concerned, many universal remote controls will work with Olevia televisions if you use the codes found under the RCA, LG, Phillips, and Yamaha in the code listing included with your remote control.
Need codes for universal remote for ilo television
I dont know which remote you are using but you might want to try these 2 codes... 0171 and 1990
These codes are also mentioned depending on which universal remote being used ...
10180 10171 10171 10179
Good Luck.
Top Hisense Televison & Video Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
