KitchenAid KGST307 Gas Kitchen Range Logo
Posted on Dec 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Spark module location
Location of the spark module
Richard Roth
Level 3:
Top Expert:
  • KitchenAid Master 9,472 Answers
  • Posted on Dec 12, 2013
Richard Roth
KitchenAid Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628721
Points
28464
The spark module is number 5 on this diagram.
Where is the spark module located on GE profile C2s985set7ss
The spark module on a GE Profile C2S985SET7SS front panel dual fuel stove is typically located behind the control panel or near the burner controls. It may be accessible by removing the control panel or by accessing a service panel on the back of the stove. For specific instructions on accessing the spark module, it is recommended to consult the owner's manual for your stove or contact a professional repair service.
tip
Cooktop Range Stove spark ignition does not work
You go to light the burner on your cooktop and the spark does not work.
What can the problem be? In most cases the problem will be because the
spark ignition module has gone bad. This spark module is a piece of electronics that produces a harmless electric spark at 2-4 pulses per second. Because the spark is a ultra low amperage spark, it is not dangerous.
A typical spark ignition will look similar to this.
This box is usually in a metal box located somewhere under the cooktop of your stove or in the back panel of your stove. The easiest way to find this is to simply follow the electric wires that go from the spark ignition box to the spark tip located at each of the burners.
The spark is activated by a switch that is located behind each of the burner control knobs. When one of the switches is turned on, all of the burners spark at the same time. The spark switch will look something like this.
To troubleshoot the spark ignition you need to determine if the system is wired in series or parallel. If the system is a series system and one is not sparking, then none will spark.
Almost every time if the spark is not working, it is because of a bad switch. To isolate which switch it is, turn each switch till you find the one that does not activate the module to spark. You can confirm this by pulling the two wires off of the switch and touching them together. If you get spark you know that the switch is bad. If no spark happens then either then a wire is bad or the module is bad. If none of the switches cause the module to spark then it is a good assumption that the spark module is bad.
By checking through these procedures you will be able to tell whether your problems are caused by a bad switch, a bad wire, or a bad spark ignition module. You will discover almost every time that the switch behind the burner is the part that needs to be replaced.
on Aug 18, 2010 • Cooktops
Location of ignition control module 2001 cadilac deville
Ignition Coils/Modules
The electronic ignition system uses an individual ignition coil for each cylinder. There are two separate ignition module assemblies located in the camshaft cover of each cylinder bank. Each ignition module assembly contains an ignition control module and four ignition coils. Each ignition coil connects directly to a spark plug using a boot. This arrangement eliminates the need for secondary ignition wires. The ignition module assemblies receive power from a fused ignition feed. Both ignition module assemblies connect to chassis ground. A Reference Low and four ignition control (IC) circuits connect each ignition module assembly to the PCM. The PCM uses the individual IC circuits to control coil sequencing and spark timing for each ignition coil. The IC circuits transmit timing pulses from the PCM to the ignition control module to trigger the ignition coil and fire the spark plug. The PCM controls ignition system sequencing and timing events
2answers
Location of the esc module on a 1994 gmc k1500 suburban & where is the wire to disconnect the esc locaticed
ESC module is for electronic spark control and is located on engine block near ignition coil . it's to control spark advance for timing.
hope it helps
Where is the spark module in viking vdsc4876gss?
I need production date to confirm but the part I found for this is PA020048 and it located in the rear of the unit If you pull out this unit, remove the rear panel, its located on the left side, mid way down.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
3.0l. Where is ignition control module located?
The coil and ignition module are part of same assembly, follow the spark plug wire, spark plug on one end, coil/ignition module on the other end.
I was going to ask, how long since a tune-up? Are there any applicable trouble codes? Are missing anything besides spark? Did you check primary voltage at the ignition module? That is a fused circuit.
2answers
Saturn 2.2 L Idles rough acts like its going to die Ive changed the spark plugs, coils, checked fuel filter, change the idle air control valve. Any suggestions what it could be Im only getting random...
Hello: I had a like condition on my 2001 Saturn L200 2.2 (over 200,000 miles) I replaced the module that is located in the upper cover on the valve cover located on the driver side. Before replacing check the connection at the module and check the connections at the PCM. PCM located on the passenger side below the cover at the bottom of the windshield.
2helpful
Where i the ignition module located ?
The ignition module is located under the coil packs on the v-6 engine.
That is where the spark plug wires go to the spark plugs . When you remove the coil packs ,the flat peice is themodule.When you remove the module , the crankshaft sensor is sometimes located there ,and that also should be changed
07f-150 no spark
Have you checked the ignition module..? If my memory serves me, you should have a module which controls the spark. This can be located anywhere so, if you have a distributor, it should be attached to that, if you have waste spark ignition, the module can be attached under the coil packs or mounted on the inner guard. Without been able to look under the hood, it is difficult to point out the exact location of the ign module..The module controls everything with regard to spark and the PCU only sends timing info to that module, the PCM does not directly control spark.. You may have a security pack issue ( if the vehicle has the security pack fitted) so check that the flashing security lamp is out when you are cranking the engine, if it is on or flashing, then the security pack has not been turned off and you will lose spark and injection pulses..
1helpful
Gas ignitors do not shut off
Are you saying the spark module is constantly sparking? If so, you may have one of your surface burner switches shorted, causing the spark module to stay on. Or, you could have a ground in your wiring harness to the spark module. Here's a way to check: 1. Unplug range, or turn off circuit breaker. 2. Locate your spark module. It's usually located in the back of the oven cavity, or behind the rear panel. There should be a wire going from the spark module to each burner switch. Carefully disconnect each burner switch one at a time and re-energize your range to see if the problem goes away. If the problem doesn't go away, turn the range back off, reconnect the switch and move to the next switch wire. 3. If you disconnect each switch and the problem persists, then I would suspect an internal short in the spark module, or a ground in your wiring somewhere. There should be a tech sheet with diagrams located somewhere on the back of the range to assist you. I hope this helps.
Top KitchenAid Kitchen Ranges Experts
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
