Water Heaters Logo
A
Anonymous Posted on Aug 01, 2017
Rheem water heater poor temperature regulation
Model 21IR40dv installed in manufactured home running on propane. Very poor temperature regulation. Setting dial to "Hot"--sometimes temp is ok then goes up too high. Today was at 130 degrees. Have had problems with water being too hot then not hot enough over the last two years. Heater has been in service since early 2009. Using well water--has some minerals but not all that bad. Any ideas?
Paul Carew
Level 3:
  • Rheem Master 3,808 Answers
  • Posted on Aug 01, 2017
Paul Carew
Rheem Master
Level 3:
Answers
3808
Questions
Helped
1299827
Points
10526
Have a look at the water section might be getting clogged inside , slowing the flow .
5 Related Answers
Anonymous
  • 332 Answers
  • Posted on May 29, 2009
SOURCE: Whirlpool Energy Smart water heater not hot
I think some one mis informed you, the normal temp on any water heater from the factory is 120, it should not go above that for reasons of sevear burns, as far as it't smart part it's just a name, you will lose a couple of degrees just comming torm the tank to the faucets, the water heater will allways keep the temp in the tank at what ever it is set at, it doesn't have the brains or computer to know what time of day it is but when the cold water comes in to the tank it comes thru a dip tube that goes to aprox 1 inch from the bottom of the tank, if you take a long shower and do not have a energy efficant shower head you can use up to 5 gals, per min of hot water where an energy efficant one only uses 2.5 or less and still has the same pressure at the shower head, the temp in your water heater tries to stay at the setting it is at depending on how much is used at one time meaning washing machine, filling tub or dishwasher at the same time, it lets more cold in as the hot goes out and as you know it can only heat up so much at a time and the cold water is just going across the bottom of the tank, so the name is just that no diffrent then any other water heater unless you went to a tankless water heater.
Anonymous
  • 332 Answers
  • Posted on Jun 06, 2009
SOURCE: when filling bathtub or running two showers, water heater howls
it could be the fact thath the water comming in is what the problem is,, on a well system the water is extra cold and the unit is working hard and with sand aso comming in it makes it harder to keep the temp up on the water,,, flush the tank, put hose on it and open the drin valve with a hose on it turn the cold water on and let it flow till the water comes out clear usually about 5 min,,, get all the sand out and other debris and try it
Anonymous
  • 115 Answers
  • Posted on Aug 19, 2009
SOURCE: Rheem Gas Hot water Heater; Model 21130DV:
yes, sounds like the temp control is bad, you should be able to google model# and thermostat to find replacement. should be fairly easy to swap out
muttandjeff
Allen Neal
  • 359 Answers
  • Posted on Jan 05, 2010
SOURCE: My rheem water heater doesn't seem to be heating
try setting the bottom 10 degrees hoter than the top could be in short cycle (thatis the bottom calls for heat on the bottom element and set too close so goes back to top and cycles off
Gene Haynes
  • 5391 Answers
  • Posted on Sep 07, 2012
SOURCE: I recently bought a park mobile home with a Rheem propane tank less model SW10D water heater. The trailer was largely vacant for the last two years. The water heater fired right up and delivered a su
Check plumbing.
Bad single-handle faucet cartridge can can hot never to arrive at tap.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Install 30 amp breaker and run 10 gauge wire from breaker box and install electric water heater for $300 total.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Zwc28 1mf2k31 poor flame
Check in coming water flow . Check water flow at heater maybe blocked inside reduced flow .
I want to convert my rheem tankless eco150xlp3 to natural gas. There is a gas type chip that plugs into the main board as described in the install manual. Opened the burner and the orifice looks servo...
Sell it on ebay.
A simple chip change will not convert because the orifice for each gas is different, the gas control valve is different, NG and LP gas each burn at different temperatures and pressures... with propane having higher temps and pressures.
Don't buy tankless computers and expect trouble-free installation and water heating bliss afterwards.
Read the manual for maintenance requirements, and look at the parts sheet and ask yourself how such a complex machine will simply balance and monitor water flow, water pressure, incoming and outgoing water temperatures, gas pressures, vent pressures, gas quality, gas pressures, while connected to water, gas, venting and electric systems inside your home which each have innumerable problems on their own.
Install tank type heater for around $400 and live worry free.
Avoid Rheem products since they do not post service manuals.
http://waterheatertimer.org/Which-is-best-gas-water-heater.html
Gene
h
Our rheem pronto tankless rutg-74xp red light will come home indicating hot water and stay on about 2 minutes and then turns off we have turned off and back on and let water run for 5 minutes and will come...
Before calling service technician, open following link for Rheem troubleshooting resources.
List of causes MIGHT include one of following:
Bad household circuit breaker that powers electronics, or loose wire inside outlet where tankless plugs in.
Tankless fuses and control board.
Water flow rate too low. Minimum .8 gallon required (depending on model)
Tankless inlet filter clogged.
Household aerators clogged at faucets.
Crossover at single-handled faucet
If installed, there can be crossover at mixing valve.
Faulty household check valve, including check valve on re-circulation system if that system is installed.
Restriction in household water line, such as clog at elbow.
Unequal pressure in household hot and cold lines, caused by restriction in hot line. When single-handled faucet turns on, the cold water pressure is higher so hot does not flow and tankless will not turn on.
Loose wire connection inside tankless.
Unit temperature set too high.
Unit temperature set too low.
Water temperature is very hot coming out of tap, so more cold is added, but that reduces amount of hot water flow, so tankless turns off because flow rate is too low.
On some tankless, if water is preheated by solar or other indirect source, the burner will not activate.
High mineral content in water > delime tankless yearly
Misaligned temperature sensor
Low gas pressure. Wrong type of gas. Undersized gas line.
Too many faucets on at same time.
Faulty tankless water valve. Water valve stuck.
Fluctuating household water pressure, for example MUD and PUD district water pressure problems or water well pressure.
Faulty household pressure reducing/regulating valve if installed.
Faulty household pressure tank, if installed -or- pressure tank needs to be installed.
I have a poloma model PTG-74PVP hot water heater. This morning we went to use it and it will run a minute or two the flash alarm 35. We have had the unit for four years with no problems what so ever.
rtgl-74xp.jpg RTG-95XP Item Name: Outdoor Rheem Tankless Water Heater RTGL-74XP Item Price: $910-$1100 Gas Type: Propane Venting: No Item SKU: Rheem RTG-95XP replaces RTG-74XP Product Description: Rheem Tankless Water Heater RTG-95XP
Be aware of this --- http://www.cpsc.gov/cpscpub/prerel/prhtml07/07108.html
And this ---
This makes getting information hard to come by. Please use the link below for information.
http://www.rheemtanklessonline.com/contact.php
30 gallon propane supply tank for residential home, seems appliances are burning too hot, flames are very high what is the cause? Regulator? O2 supply?
could you have gotten a natural gas tank by mistake? it would have larger orfices and allow more gas than you need propane has more B.T.U.s than nat gas and requires a smaller orfice
chack with your gas co.good luck.
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
