The extension name and extension number are set in the system programming. Use manager 'e' and change them in the station view. If you are swapping people around and want them to keep their extension numbers and names, you should re-patch the cables feeding to the wall sockets rather than change the programming (if you can).
Hi Amy, you can change the name for an extension, but it will change the name for the extension for all the phones.
It is best to do programming on a T7316, M7310, or an M7324
1. Feature **23646
2. Password: 266344
>>>your password may have been changed by your phone company. contact them for the password.
3. Scroll to General Admin
4. Go to Names
5. Select Set Names
6. Enter in the DN of the extension you would like to change
7. Use the dial pad to change the extension.
8. Press Rls when finished (handset with arrow facing down)
Go to control panel then go to folder option then click on view tab. On the list you'll find a option named "Hide extensions for known file type". Enable this option and click OK. Now you can rename your files easily.
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Without picking up the handset, press program *# 1234. 003.
keeping pressing the speaker phone until the extn u want to change is displayed. Note down the jack no.
Then press hold and 004. Then press speaker phone 1 time and enter the jack no of the extension whose name has to be changed. then change
the name. After you finish entering the name press autodial.
go to file/save as change the name of the file, make sure that <.scrapbook> is not in the name the box under file name, you can change the extension, just scroll down to find the extension you want
Feature 00 Left intercom Left intercom Right intercom enter the extension you want to modify press the left intercom Enter the name. When finished, press feature 00 to exit programming.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
